Hello again.
I hope not to ban me for overwriting post. But today i found one very interesting function. And do some research how i can use it in some lisp and i found this method which i think is interesting.
After my research 5-6 hours i cannot find any information how to use it.
I take some info from Here and try everything i can. Also i try This because i think this will be more easy.
I attach .dwg and code where is very wrong i think but...
(defun LM:group-n ( l n / r )
    (if l
        (cons
            (reverse (repeat n (setq r (cons (car l) r) l (cdr l)) r))
            (LM:group-n l n)
(defun gc:3dPointListToVariant (lst)
  (vlax-make-variant
    (vlax-safearray-fill
      (vlax-make-safearray
        vlax-VbDouble
        (cons 0 (1- (* 3 (length lst))))
      (apply 'append lst)
(defun c:dd2 (/ selL VnamL VnamS coord inv)
(setq selL (car (entsel "\nSelect Poly..")))
(setq VnamL (vlax-ename->vla-object selL))
(setq coord (gc:3dPointListToVariant (LM:group-n (vlax-get VnamL 'coordinates) 3)))
(setq selS (car (entsel "\nSelect volumeSurf..")))
(princ "\n")
(setq VnamS (vlax-ename->vla-object selS))
(setq inv (vl-catch-all-apply 'vlax-invoke-method (list (vlax-get VnamS 'Statistics) 'BoundedVolumes coord)))
(princ inv)
;(princ (vl-catch-all-error-message inv))
And only to say, dont be mad at me im not a programmer this is just hobby :)
And thank for all help, where you gave me :)
Test3.dwgUnavailable
http://www.lee-mac.com/groupbynum.html
  On 4/22/2021 at 2:41 PM, Trudy said:
Hello again.
    (if l
        (cons
            (LM:group-n l n)
  (vlax-make-variant
        vlax-VbDouble
      (apply 'append lst)
(princ "\n")
(princ inv)
Expand
Please put the question here
https://forums.autodesk.com/t5/civil-3d-customization/bd-p/190
Hello this is what i do.
If someone need it.
(defun T:endP (pline /  endpoint end start all all2); retund list ((x1 y1 0) (x2 y2 0) ... (Xn Yn 0))
;pline - Visual name on Polyline
(setq close (vlax-get pline 'Closed))
(if (equal (vlax-get pline 'ObjectName) "AcDbPolyline")
			(setq endpoint  (vlax-get pline 'coordinates))
				(setq start (list (car endpoint) (cadr endpoint)))
				(setq end (list (cadr (reverse endpoint)) (car (reverse endpoint))))
					(if (equal start end)
							(setq all (append (LM:group-n endpoint 2) (list start)))
							(setq all2 (mapcar '(lambda (x) (append x (list 0))) all))
					(if (equal close '-1)
all2
;Lisp for return bounded volume from TIN Volume surface
;Creator: Trudy
;Date:27.04.2021
(defun c:BoundedVolume (/ selL VnamL VnamS coord inv)
(setq coord (gc:3dPointListToVariant (T:endP VnamL)))
(setq inv (vl-catch-all-apply 'vlax-invoke-method (list (vlax-get VnamS 'Statistics) 'BoundedVolumes coord 'pCut 'pFill 'pNet)))
(princ "\n")
(princ (rtos pCut 2 3))
(princ "\n")
(princ (rtos pFill 2 3))
Used lisp: Lee mac - http://www.lee-mac.com/groupbynum.html
                  gile - https://www.theswamp.org/index.php?topic=31674.0
