Trudy Posted April 22, 2021 Posted April 22, 2021 Hello again. I hope not to ban me for overwriting post. But today i found one very interesting function. And do some research how i can use it in some lisp and i found this method which i think is interesting. After my research 5-6 hours i cannot find any information how to use it. I take some info from Here and try everything i can. Also i try This because i think this will be more easy. I attach .dwg and code where is very wrong i think but... (defun LM:group-n ( l n / r ) (if l (cons (reverse (repeat n (setq r (cons (car l) r) l (cdr l)) r)) (LM:group-n l n) ) ) ) (defun gc:3dPointListToVariant (lst) (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-VbDouble (cons 0 (1- (* 3 (length lst)))) ) (apply 'append lst) ) ) ) (defun c:dd2 (/ selL VnamL VnamS coord inv) (setq selL (car (entsel "\nSelect Poly.."))) (setq VnamL (vlax-ename->vla-object selL)) (setq coord (gc:3dPointListToVariant (LM:group-n (vlax-get VnamL 'coordinates) 3))) (setq selS (car (entsel "\nSelect volumeSurf.."))) (princ "\n") (setq VnamS (vlax-ename->vla-object selS)) (setq inv (vl-catch-all-apply 'vlax-invoke-method (list (vlax-get VnamS 'Statistics) 'BoundedVolumes coord))) (princ inv) ;(princ (vl-catch-all-error-message inv)) (princ) ) And only to say, dont be mad at me im not a programmer this is just hobby And thank for all help, where you gave me Test3.dwgFetching info... Quote
hosneyalaa Posted April 23, 2021 Posted April 23, 2021 On 4/22/2021 at 2:41 PM, Trudy said: Hello again. I hope not to ban me for overwriting post. But today i found one very interesting function. And do some research how i can use it in some lisp and i found this method which i think is interesting. After my research 5-6 hours i cannot find any information how to use it. I take some info from Here and try everything i can. Also i try This because i think this will be more easy. I attach .dwg and code where is very wrong i think but... (defun LM:group-n ( l n / r ) (if l (cons (reverse (repeat n (setq r (cons (car l) r) l (cdr l)) r)) (LM:group-n l n) ) ) ) (defun gc:3dPointListToVariant (lst) (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-VbDouble (cons 0 (1- (* 3 (length lst)))) ) (apply 'append lst) ) ) ) (defun c:dd2 (/ selL VnamL VnamS coord inv) (setq selL (car (entsel "\nSelect Poly.."))) (setq VnamL (vlax-ename->vla-object selL)) (setq coord (gc:3dPointListToVariant (LM:group-n (vlax-get VnamL 'coordinates) 3))) (setq selS (car (entsel "\nSelect volumeSurf.."))) (princ "\n") (setq VnamS (vlax-ename->vla-object selS)) (setq inv (vl-catch-all-apply 'vlax-invoke-method (list (vlax-get VnamS 'Statistics) 'BoundedVolumes coord))) (princ inv) ;(princ (vl-catch-all-error-message inv)) (princ) ) And only to say, dont be mad at me im not a programmer this is just hobby And thank for all help, where you gave me Test3.dwg 781.73 kB · 2 downloads Expand Please put the question here https://forums.autodesk.com/t5/civil-3d-customization/bd-p/190 Quote
Trudy Posted April 28, 2021 Author Posted April 28, 2021 Hello this is what i do. If someone need it. (defun T:endP (pline / endpoint end start all all2); retund list ((x1 y1 0) (x2 y2 0) ... (Xn Yn 0)) ;pline - Visual name on Polyline (setq close (vlax-get pline 'Closed)) (if (equal (vlax-get pline 'ObjectName) "AcDbPolyline") (progn (setq endpoint (vlax-get pline 'coordinates)) (setq start (list (car endpoint) (cadr endpoint))) (setq end (list (cadr (reverse endpoint)) (car (reverse endpoint)))) (if (equal start end) (progn (setq all (append (LM:group-n endpoint 2) (list start))) (setq all2 (mapcar '(lambda (x) (append x (list 0))) all)) ) (if (equal close '-1) (progn (setq all (append (LM:group-n endpoint 2) (list start))) (setq all2 (mapcar '(lambda (x) (append x (list 0))) all)) ) ) ) ) ) all2 ) ;Lisp for return bounded volume from TIN Volume surface ;Creator: Trudy ;Date:27.04.2021 (defun c:BoundedVolume (/ selL VnamL VnamS coord inv) (setq selL (car (entsel "\nSelect Poly.."))) (setq VnamL (vlax-ename->vla-object selL)) (setq coord (gc:3dPointListToVariant (T:endP VnamL))) (setq selS (car (entsel "\nSelect volumeSurf.."))) (setq VnamS (vlax-ename->vla-object selS)) (setq inv (vl-catch-all-apply 'vlax-invoke-method (list (vlax-get VnamS 'Statistics) 'BoundedVolumes coord 'pCut 'pFill 'pNet))) (princ "\n") (princ (rtos pCut 2 3)) (princ "\n") (princ (rtos pFill 2 3)) (princ) ) Used lisp: Lee mac - http://www.lee-mac.com/groupbynum.html gile - https://www.theswamp.org/index.php?topic=31674.0 Quote
