Match rotate angel to another block
Lisp to match rotation angel to another block (first click on a block that rotation pick then another click on another block apply)
This has nothing to do with a higher power, but it will match the ANGLE of a picked block to a selection. 😇
(defun c:foo (/ a e s)
  (if (and (setq e (car (entsel "\nPick a block to match rotation: ")))
	   (setq a (cdr (assoc 50 (entget e))))
	   (setq s (ssget ":L" '((0 . "INSERT"))))
    (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
      (vla-put-rotation (vlax-ename->vla-object e) a)
@ronjonp & @tombu
many thanks to both of you and your valuable contributions ... both of your suggestions work perfectly !
thanks again
  On 4/21/2021 at 2:44 PM, sivapathasunderam said:
@ronjonp & @tombu
thanks again
Expand
Glad to help 🍻
Here is a version to rotate all objects with a rotation property:
(defun c:foo (/ a e o s)
  (if (and (setq e (car (entsel "\nPick something to match rotation: ")))
	   (setq s (ssget ":L"))
      (if (vlax-property-available-p (setq o (vlax-ename->vla-object e)) 'rotation)
	(vla-put-rotation o a)
  • Thanks 1
