Curious what this would be for.
Why not just use Annotative Text with orientation set to layout?
It is a file in which there are already many texts and I want to convert them to block and macth block orientation to layout.
Would a lisp that converts those texts to Annotative Text at the current scale with orientation set to layout suit your needs?
Seems cleaner than adding a bunch of blocks to the drawing that you would need the block editor to modify. You wouldn't even be able to search for text that was part of a block.
I'm fine with what you say.
Can you pass me that lisp, please.
Thanks
In that post they talk about changing the text options from properties. What I do not know how to do is that the text is oriented by itself with the rotation of the presentation, as the block does when marking the option "Macth block orientation to layout".
Thank you
59 minutes ago, Truski said:
In that post they talk about changing the text options from properties. What I do not know how to do is that the text is oriented by itself with the rotation of the presentation, as the block does when marking the option "Match block orientation to layout".
Thank you
Yes you can do it in the Properties Palette.
It must be set to annotative first to see the option to "Match block orientation to layout". When set in Properties the text will always be displayed horizontal in a viewport. Of course if you viewed it on the model tab in a twisted view it would not as it would have no layout to reference but if it's easier to select all that text on the Model tab it works. The text will be horizontal in any layout viewport.
Tomorrow I will try it.
Thank you so much for everything.
It's great, it works perfectly.
Thank you very much for your help.
