kennykramer Posted February 9, 2009 Posted February 9, 2009 I have a cal-comp drawing board III with custom menus for 2000, and now I am wanting to migrate them into the 2007 program can any one help me here?? they are in mnu and mnc format . Please help if you can Kenny kenny45_67333@hotmail.com Quote
ReMark Posted February 9, 2009 Posted February 9, 2009 Did you attempt to bring them over using the Migration tools? You could just cut and paste between menu files. Don't try it with the .mnc file as that is the compiled version. Quote
ASMI Posted February 9, 2009 Posted February 9, 2009 _MENULOAD command still works and now generate partial *.cui file with the same name. Quote
kennykramer Posted February 9, 2009 Author Posted February 9, 2009 yes but when I load the menu it makes all the buttons on my pulldown menus turn into ? and you cant read them anymore any ideas how to get them back?? the tablet works great but the menu buttons that bites, please help thanks Kenny kenny45_67333@hotmail.com Quote
kennykramer Posted February 9, 2009 Author Posted February 9, 2009 by ? I mean an actuall question mark Quote
ASMI Posted February 9, 2009 Posted February 9, 2009 It is difficult to help you as do not show us your files. At you is *.bmp files for buttons? Quote
kennykramer Posted February 10, 2009 Author Posted February 10, 2009 wheich files would you like me to show and how do I show them? Quote
ReMark Posted February 10, 2009 Posted February 10, 2009 I think ASMI would like to see the bitmap file your using for your icon of the question mark (?). Quote
JONTHEPOPE Posted February 10, 2009 Posted February 10, 2009 Did you try to type cui in command line cui than look for your legacy tab here where you should put you files for me my mnu file didn't work right so i just drag and dropped icons i needed in tablet menus row a line row b circle etc.. Quote
kennykramer Posted April 17, 2009 Author Posted April 17, 2009 Holy One how do I put tablet cui into the legacy tab?? sorry I am so ignorant about such things Quote
kennykramer Posted April 17, 2009 Author Posted April 17, 2009 and how would I know where to look for the bmp files Quote
kennykramer Posted April 17, 2009 Author Posted April 17, 2009 where do I find the bmp files for the icons? what files would you like to see and how do I show you?? Quote
kennykramer Posted April 17, 2009 Author Posted April 17, 2009 please help me here I am needing to be able to use the new software and still havent figured out how to set up my tablet and saddly I am an old timer who is very used to my tablet with my menus HELP Quote
lpseifert Posted April 17, 2009 Posted April 17, 2009 If you have the .mnu and/or .mns file that has the tablet setup, try menuload. Quote
The Buzzard Posted April 17, 2009 Posted April 17, 2009 The correct command to import a menu file into a cui file is : cuiimport. 1. Enter cuiimport at the command prompt. 2. The Customize User Interface dialog appears. 3. Click the popup list at the top and select Open... 4. Then click on the yellow folder on the left side to browse for your tablet menu. 5. Make sure where it says file type you select Menu Files. 6. You then select your tablet menu and click OK. 7. Under Legacy your menus will appear there. 8. Simply drag them to the right side under Legacy. 9. Hit Apply to save. Thats it! Your tablet menu is now converted to the CUI Good Luck, The Buzzard Quote
