Janouren Posted April 12, 2021 Share Posted April 12, 2021 (edited) Good day, I'm a student of construction engineering and recently I got student's job at a projection firm with a lot of old-school engineers and the workflow here was very slow. We get a bunch of maps with their own layers and blocks and up to this point, people here were replacing blocks&layers from these drawings one by one with our own custom blocks and layers (thousands of blocks!). So far I've learned how to implement LISPS and found layertransfer to automatically change layers to our layers, with settings saved to file allblockreplace LISP by alanjt to replace all selected blocks to a new replacement block Replacing layers and blocks en-masse is my main objective. allblockreplace increased speed of work significantly, but it's still loads of manual labour that I hope you could please help me with. It pains me to see these old engineers using their human hours to pick and replace blocks one by one and I'd also like to learn for myself how to do this. I found this LISP that almost does the trick by Tharwat: (defun c:Test (/ lst ss i sn en f) ;;--------------------------------------------;; ;; Author : Tharwat . Date: 09.June.2015 ;; ;; A function to replace a set of block names ;; ;; with a nother as per listed in the list ;; ;;--------------------------------------------;; (setq lst '(("old*" . "new") ("sad*" . "happy") ) ) (if (setq ss (ssget "_X" (list '(0 . "INSERT") (cons 2 (apply 'strcat (mapcar '(lambda (x) (strcat (car x) ",")) lst)))))) (repeat (setq i (sslength ss)) (setq sn (ssname ss (setq i (1- i))) en (entget sn)) (if (and (setq f (assoc (cdr (assoc 2 en)) lst)) (tblsearch "BLOCK" (cdr f)) (entmake (append (list '(0 . "INSERT") (cons 2 (cdr f))) (vl-remove-if-not '(lambda (v) (member (car v) '(6 8 10 41 42 43 50 62))) en))) ) (entdel sn) ) ) ) (princ) ) In short, I input a list of blocks that we receive with the raw drawings on the left side and I input a list of our replacement blocks to the right side. Thing is, there are blocks of the same shape in the raw drawings called 3040111,304012,304013,304014,304015 and so on... with always the first 6 numbers being the same. I tried using a wildcard - replacing "old" with "3040*" but that doesn't seem to work with LISP unfortunately. Is there a way to make "old" string search for all strings that start with for example "3040" so that I can change all 3040111,304012,304013,304014,304015 to a "new" block? Edited April 12, 2021 by Janouren Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 13, 2021 Share Posted April 13, 2021 Is this the 3rd post you have requested the same 3040 blocks you only need to post once ! Quote Link to comment Share on other sites More sharing options...
Janouren Posted April 13, 2021 Author Share Posted April 13, 2021 My apologies. The other 2 instances are replies to already existing posts, this is the only post that I've started for this issue. I tried removing the other 2, but I'm not sure if it's even possible. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted April 13, 2021 Share Posted April 13, 2021 (edited) Give this a try: (defun c:test (/ en f i lst sn ss x) ;;--------------------------------------------;; ;; Author : Tharwat . Date: 09.June.2015 ;; ;; A function to replace a set of block names ;; ;; with a nother as per listed in the list ;; ;;--------------------------------------------;; (setq lst '(("3040*" . "new"))) (if (setq ss (ssget "_X" (list '(0 . "INSERT") (cons 2 (apply 'strcat (mapcar '(lambda (x) (strcat (car x) ",")) lst))) ) ) ) (repeat (setq i (sslength ss)) (setq sn (ssname ss (setq i (1- i))) en (entget sn) n (cdr (assoc 2 en)) ) (if (and ;; RJP » 2021-04-13 ;; Added support for wildcards (vl-some '(lambda (x) (and (wcmatch (strcase n) (strcase (car x))) (setq r (cdr x)))) lst) (tblsearch "BLOCK" r) (entmake (append (list '(0 . "INSERT") (cons 2 r)) (vl-remove-if-not '(lambda (v) (member (car v) '(6 8 10 41 42 43 50 62))) en) ) ) ) (entdel sn) ) ) ) (princ) ) Edited April 13, 2021 by ronjonp 1 Quote Link to comment Share on other sites More sharing options...
Janouren Posted April 26, 2021 Author Share Posted April 26, 2021 ronjonp this worked perfectly, thank you! Quote Link to comment Share on other sites More sharing options...
ronjonp Posted April 26, 2021 Share Posted April 26, 2021 Glad to help .. though the credit should be mostly to @Tharwat 1 Quote Link to comment Share on other sites More sharing options...
