JoeS09 Posted April 8, 2021 Posted April 8, 2021 I have been saving DFX files in AutoCAD 2018 in the following DFX formats - 2018, R2, 2000. Is there any way of finding out which of these formats is used in any DXF file? Quote
tombu Posted April 8, 2021 Posted April 8, 2021 https://forums.autodesk.com/t5/autocad-forum/how-to-find-version-what-version-dxf-format-we-are-saving-the/m-p/2442367#M334861 Open the DXF file in Notepad and look at the 2nd line under $ACADVER at the top of the file If R12 DXF then it = AC1009 If 2000 DXF then it = AC1015 If 2004 DXF then it = AC1018 If 2007 DXF then it = AC1021 You can also do the same test with a DWG file to see its version. 1 Quote
