lisp for area
harshad
hi all i want a lisp for area ,if i select one ,circle, rec , poly, ect..
lisp want to put area or perimeter on drawing see exzample
lisp should ask for text hight and area or perimeter
please help me
sample.pdf
Give this a try
~'J'~
[/c(defun C:alb (/ acsp adoc ar axss hgt maxp minp obj p1 p2 pc ss txt)
(vl-load-com)
(setq	adoc (vla-get-activedocument
      (vlax-get-acad-object)
(if (and
(= (getvar "tilemode") 0)
(= (getvar "cvport") 1)
(setq acsp (vla-get-paperspace adoc))
(setq acsp (vla-get-modelspace adoc))
(vla-startundomark (vla-get-activedocument
                      (vlax-get-acad-object)))
(initget 7)
(setq hgt (getreal "\nEnter text height: "))
(prompt "\nSelect objects on screen to add area label")
(if (setq ss (ssget))
   (setq axss (vla-get-activeselectionset adoc))
(vlax-for obj axss
(if (not
(vl-catch-all-error-p
 (setq
   ar (vl-catch-all-apply
          (function (lambda()
                        (vlax-curve-getarea obj)))))))
(setq txt (strcat "Area = " (rtos ar 2 2)))
(vla-getboundingbox obj 'minp 'maxp)
(setq p1 (vlax-safearray->list minp)
 p2 (vlax-safearray->list maxp)
 pc (mapcar (function (lambda(a b)(/ (+ a b) 2))) p1 p2)
(vlax-invoke acsp 'Addtext txt pc hgt)
(vla-endundomark (vla-get-activedocument
(princ "\nType ALB to label objects with area text")
fatty this is good and work fine
but lisp ask me for perimiter also :)
make like this i m thankful to u
harshad:)
Please attach the picture where you
want to put perimeter text
Do you want to put them on the
second line below the area text or
somewhere else?
~'J'~
Try edited version
(defun C:alb (/ acsp adoc ar axss hgt maxp minp obj p1 p2 pc1 pc2 per
               ss txt1 txt2)
(vl-load-com)
(if (and
(initget 7)
(setq hgt (getreal "\n  Enter text height: "))
(prompt "\n  Select objects on screen to add area label")
(vlax-for obj axss
(if
(and
(not
 (setq
          (function (lambda()
(not
   (setq
   per (vl-catch-all-apply
          (function (lambda()
                        (vlax-curve-getdistatparam obj
                             (vlax-curve-getendparam obj)))))))))
(setq txt1 (strcat "Area = " (rtos ar 2 2)))
(setq txt2 (strcat "Perimeter = " (rtos per 2 2)))
 pc1 (mapcar (function (lambda(a b)(/ (+ a b) 2))) p1 p2)
 pc2 (mapcar '- pc1 (list 0 (* hgt 1.5) 0))
(vlax-invoke acsp 'Addtext txt1 pc1 hgt)
(vlax-invoke acsp 'Addtext txt2 pc2 hgt)
(princ "\n   Type ALB to label objects with area and perimeter text")
(C:alb)
~'J'~
  • 2 weeks later...
So I copied the above lsp and used it after slight modifications, but ran into problems in certain situations.
Please look at the attached drawing:
(1) is from a drawing drawn in rotated UCS and (2) is a boundary generated in another drawing. The boundary has some co-linear lines segmented. If the segments are replaced with a single line then the code works. As it is, this boundary does not generate any error message but (1) does as below:
Enter text:
Command: Area= 226.52 Unknown command "AREA= 226.52". Press F1...
Enter text:
Command: Perimeter= 65.14 Unknown command "PERIMETER= 65.14". Press F1...
I am not exactly new to AutoLISP but neither am I a pro at it. Can someone please trouble shoot?
The modifications I have done to the code is to generate text height by picking on an existing text instead of typing and have text centre aligned. Relevant portion of text height pick is:
(setQ txts (entsel "\nSelect TEXT to match height: "))
(setQ txt1 (entget (car txts)))
(setQ txht (cdr (assoc 40 txt1)))
In place of:
(initget 7)
Please note some variables have been changed. I am yet to include error check on the text pick, which I hope to learn sooner rather than later.
Thanks,
Guite
Edit: The test file Test1.dwg is 1mb, so I copied its contents to a new (blank) file, named it Test2.dwg and attached. Now (1) is working but (2) still does not work.
Test2.dwg
Thanks Fatty, take your time. If it helps, here is my modified version of your code:
(defun C:ab (/ acsp adoc ar axss txht maxp minp obj p1 p2 pc1 pc2 per
               ss txts txt1 txt2)
(vl-load-com)
(if (and
(prompt "\n  Select OBJECTS on screen to add area label")
(vlax-for obj axss
(if
(and
(not
 (setq
          (function (lambda()
(not
   (setq
          (function (lambda()
(setq txt1 (strcat "Area= " (rtos ar 2 2)))
(setq txt2 (strcat "Perimeter= " (rtos per 2 2)))
     pc2 (mapcar '- pc1 (list 0 (* txht 1.5) 0))
(command "text" "c" pc1 txht "" txt1)
(command "text" "c" pc2 txht "" txt2)
(princ "\n   Type AB to label objects with area and perimeter text")
(C:ab)
Guite
Fatty,
No, it's not solved. Quote form my first post:
The code I have posted above is my modified version, it does not work on graphic (1) and graphic (2) of my test file. (Please note that the test file I have posted is not the one I am using, which is 1mb size, but same content, apparently).
Interestingly, your edited version works on graphic (1) but not on graphic (2). So if yours work on (1) and not (2) but mine does not work on both, can some of the changes I have made to the code be responsible, for instance, the line for text insertion and alignment?
Cheers,
Guite
  • 2 years later...
Hey Fixo how R U? :-)
Can you make this lisp divide the area value by lets say 100.
So instead of saying 1245.00 the text will say 12.45.
Can this be done?
Many thanx my friend!
Can this be done?
Hi,
Try to change these lines:
on
(setq txt1 (strcat "Area= " (rtos (/ ar 100) 2 2)))
(setq txt2 (strcat "Perimeter= " (rtos (/ per 10) 2 2)))
HTH
~'J'~
