If possible, help How do I get rid of ''"
HI ALL
I HAVE  (NAME ELEMENT  AND TEXT ) FROM  READING  CSV FILE
 (setq f (open FilePath "r"))
(setq ln (read-line f))
(setq ln  ("57" "<Entity name: 2cedba90>") )
I WANT  TO  GIVE ME
"<Entity name: 2cedba90>"  >>>>TO >>> <Entity name: 2cedba90>
(setq obj  (vlax-ename->vla-object <Entity name: 2cedba90> )
  (vlax-put obj 'textstring "57")
THANKS FOR ALL
ENAMES are not constant over different acad sessions, so even restoring them from text (which is impossible) would be useless.
Instead, you should save the handle of the entity as text and restore it with (handent <handle>).
_$ e
<Entity name: 21f6b3c3a00>
_$ (setq h (cdr (assoc 5 (entget e))))
"180408"
_$ (handent h)
  • Thanks 1
Stefan BMR
THANK YOU
IT IS GOOD IDEA
THANK YOU
Edited by hosneyalaa
