Symbol Scale in Family
I am new to Revit
I need to know how to switch scales between the annotation and the family i have created. This may not be the correct terminology like i said i was new. The annotation becomes about six times larger in the family than it is in the annotation.
Please help!! If you need more info i will provide it
Thanks in advance for any and all responses.
  • 2 weeks later...
Hey,
Your model will always be to scale because of how revit manages it. Whatever the scale is set to in the view will be the scael it prints at. As far as the text.. you may be using a large text. Select your text and go to element properties. I would suggest 3/32" or 1/8" for the size of the text for notes and dimensions and larger for titles, etc...
