The program does not work as it does on the website. something wrong ?
when I try to use the program and pass the correct parameters (same as the site) I don't have the same result as the site, is something wrong?
(LM:UnFormat "{\\O\\C1;L\\C256;ee} {\\L\\C2;M\\C256;ac}" nil)
Returns empty string
(LM:UnFormat "\\A1;{\\T1.1;\\C1;a\\C256; \\H1.2x;\\C2;b\\H0.83333x;\\C256; \\C3;c} {\\H0.7x;\\C4;\\S1#2;}" nil)
(LM:UnFormat "ADB10\\PADB10.1\\PADB10.2" nil)
"ADB10 "
A piece of string is missing
;;-------------------=={ UnFormat String }==------------------;;
;;  Returns a string with all MText formatting codes removed. ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  str - String to Process                                   ;;
;;  mtx - MText Flag (T if string is for use in MText)        ;;
;;  Returns:  String with formatting codes removed            ;;
(defun LM:UnFormat ( str mtx / _replace rx )
    (defun _replace ( new old str )
        (vlax-put-property rx 'pattern old)
        (vlax-invoke rx 'replace str new)
    (if (setq rx (vlax-get-or-create-object "VBScript.RegExp"))
            (setq str
                (vl-catch-all-apply
                    (function
                        (lambda ( )
                            (vlax-put-property rx 'global     actrue)
                            (vlax-put-property rx 'multiline  actrue)
                            (vlax-put-property rx 'ignorecase acfalse)
                            (foreach pair
                                    ("\032"    . "\\\\\\\\")
                                    (" "       . "\\\\P|\\n|\\t")
                                    ("$1"      . "\\\\(\\\\[ACcFfHLlOopQTW])|\\\\[ACcFfHLlOopQTW][^\\\\;]*;|\\\\[ACcFfHLlOopQTW]")
                                    ("$1$2/$3" . "([^\\\\])\\\\S([^;]*)[/#\\^]([^;]*);")
                                    ("$1$2"    . "\\\\(\\\\S)|[\\\\](})|}")
                                    ("$1"      . "[\\\\]({)|{")
                                (setq str (_replace (car pair) (cdr pair) str))
                            (if mtx
                                (_replace "\\\\" "\032" (_replace "\\$1$2$3" "(\\\\[ACcFfHLlOoPpQSTW])|({)|(})" str))
                                (_replace "\\"   "\032" str)
            (vlax-release-object rx)
            (if (null (vl-catch-all-error-p str))
                str
(vl-load-com)
returns "Lee Mac" exactly as it does in his example at http://www.lee-mac.com/unformatstring.html
on my PC.
Command: (LM:UnFormat "{\\O\\C1;L\\C256;ee} {\\L\\C2;M\\C256;ac}" nil)
"Lee Mac"
Command: (LM:UnFormat "ADB10\\PADB10.1\\PADB10.2" nil)
"ADB10 ADB10.1 ADB10.2"
Command: (LM:UnFormat "\\A1;{\\T1.1;\\C1;a\\C256; \\H1.2x;\\C2;b\\H0.83333x;\\C256; \\C3;c} {\\H0.7x;\\C4;\\S1#2;}" nil)
"a b c 1/2"
Edited by tombu
added command line output
Same here with the examples above.
Quote
"Lee Mac"
"a b c 1/2"
same here... what autocad version are you working with?
Looking at master Lee's code , he uses
and
(if (null (vl-catch-all-error-p str)) str)
Just thinking aloud , maybe VBScipt part isn't working , if so vl-catch-all-error kicks in?
Thank you all for testing the function - I'm pleased to see that the function is performing as expected in the majority of cases.
@Anushka If you are using the very latest version of AutoCAD in which the LISPSYS system variable is present, please try setting LISPSYS=0, as I've found that the introduction of Unicode compatibility to AutoLISP has impacted the evaluation of Regular Expressions such as used by my LM:Unformat function.
and
A good suggestion @rlx and thank you for testing the code, however if the vl-catch-all-apply expression were to return an error object, or if the LM:Unformat function cannot instantiate the Regular Expressions object, the function would return nil, rather than the mixed results reported by the OP.
@Lee , I was looking for something like (If err "" str) but couldn't find it but also didn't want to blame you so I blamed the next best thing 😄 , first time I hear that LISPSYS probably is to blame. Thanx for the intel :thumbsup:
I've been using Civil 3D 2021 since the first update and use a lot of code from Lee and others. I've never had an issue.
Anushka are you still using AutoCAD 2014? Have updates been installed?
