Bill Tillman Posted March 27, 2021 Share Posted March 27, 2021 I have prepared the attached 3D model of a relatively simple concrete ramp for a commercial project. Just like so many times in the past I keep running into this same issue. So is it an issue with AutoCAD or an issue with the user...or as we used to say, a short circuit between the seat and keyboard ... ie. user error? Ramp Rails.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 27, 2021 Share Posted March 27, 2021 Did ucs ob picked b, at a-b there is a radius, I moved the a-b away using grips and reconnected to end of b then did PEDIT join etc Quote Link to comment Share on other sites More sharing options...
lrm Posted March 27, 2021 Share Posted March 27, 2021 Where A meets B you have three lines and they do not end at the same point. Here's a magnified image of the junction where I have move the 3 lines apart. BTW, the lines do not need to be collinear to convert them to a polyline. They must lie on the same plane however and share end points. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 27, 2021 Share Posted March 27, 2021 Like you Lrm I did not look as hard moved the wrong line, but a drafting problem. Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted March 27, 2021 Author Share Posted March 27, 2021 Thanks all. I knew it had to be sloppy drafting so I went back and carefully laid it out again. I got the grabrail to be one continuous piece all the way up and around the ramp surfaces. But it's not there yet. Will hack at this a little more tonight and post results tomorrow. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 27, 2021 Share Posted March 27, 2021 more tonight !! No its time to go fishing brilliant sunshine, low wind on the lake. 1 Quote Link to comment Share on other sites More sharing options...
