I have prepared the attached 3D model of a relatively simple concrete ramp for a commercial project. Just like so many times in the past I keep running into this same issue. So is it an issue with AutoCAD or an issue with the user...or as we used to say, a short circuit between the seat and keyboard ... ie. user error?
Ramp Rails.dwg
Did ucs ob picked b, at a-b there is a radius, I moved the a-b away using grips and reconnected to end of b then did PEDIT join etc
Where A meets B you have three lines and they do not end at the same  point.
Here's a magnified image of the junction where I have move the 3 lines apart.
BTW, the lines do not need to be collinear to convert them to a polyline.  They must lie on the same plane however and share end points.
Like you Lrm I did not look as hard moved the wrong line, but a drafting problem.
Thanks all. I knew it had to be sloppy drafting so I went back and carefully laid it out again. I got the grabrail to be one continuous piece all the way up and around the ramp surfaces. But it's not there yet. Will hack at this a little more tonight and post results tomorrow.
 more tonight  !! No its time to go fishing brilliant sunshine, low wind on the lake.
