ScoRm Posted March 24, 2021 Share Posted March 24, 2021 this is a bit of a stretch... but, is it possible to rotate LEADER at an specific angle? what i do is i make a temporary line and use the "@any length < the angle" like "@5<45" and then snap the LEADER to that line.. then i just add the text beside it.. but whats important here is the angle of the leader. so im asking if it is even possible? Base Angle: North new block.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 25, 2021 Share Posted March 25, 2021 Its not that hard ask for distance and angle, pick arrow head point pt1. So work out via Polar end point pt2 , then just look at mleader prompts can supply pt1 pt2 when asked for points, again using polar work out the text insertion point using Left mid as alignment. A start for you (command "mleader" pt1 pt2 "") I would use Multi getvals in Cadtutor\downloads. Quote Link to comment Share on other sites More sharing options...
ScoRm Posted March 25, 2021 Author Share Posted March 25, 2021 5 hours ago, BIGAL said: Its not that hard ask for distance and angle, pick arrow head point pt1. So work out via Polar end point pt2 , then just look at mleader prompts can supply pt1 pt2 when asked for points, again using polar work out the text insertion point using Left mid as alignment. A start for you (command "mleader" pt1 pt2 "") I would use Multi getvals in Cadtutor\downloads. Thank you sir, i will this one. Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted March 25, 2021 Share Posted March 25, 2021 (edited) If you use MLEADERS you can "force" an angle Edited March 25, 2021 by ILoveMadoka Quote Link to comment Share on other sites More sharing options...
