Freeze currently selected multi objects
Jest
I need a lisp routine to freeze currently selected objects on multi different layers at once.
Instead to run LAYFRZ command and pick them one by one, I would like to select them
first (like window selection) and then run single command to freeze them and so theirs layers all at once.
Any Ideas?
(defun c:Test (/ i s c e y l b k)
  ;; Tharwat - Date: 24.Mar.2021			;;
  ;; Freeze layers of selected objects			;;
  ;; NOTE: excludes if any of the layers is current.	;;
  (and (princ "\nSelect objects to Freeze their layers : ")
       (setq c (getvar 'CLAYER)
             i -1
             s (ssget '((0 . "~VIEWPORT")))
       (while (setq i (1+ i)
                    e (ssname s i)
         (or (member (setq y (cdr (assoc 8 (entget e)))) l)
             (= c y)
             (and (setq l (cons y l)
                        b (entget (tblobjname "LAYER" y))
                        k (assoc 70 b)
                  (entmod (subst (cons 70 (1+ (cdr k))) k b))
