I have several blocks that have fields created withing them,
when I insert the block into a drawing then go to Drawing Utilities -> Drawing Properties
those fields are not in the list to edit.
I know how to go through the tedious steps of manually re-entering every single field
but wondered if there is a way to get those fields to "add automatically"
upon insertion into the drawing.
Please advise.
Wow... I have never heard of that command.
Unfortunately the Propulate command expects that the fields are pre-exisiting and simply updates them.
It does not insert/import/create them even from other drawings or templates..
(Or I cannot figure out how to get it to work correctly)
Edited by ILoveMadoka
update
A simple pline and area field worked copied to another dwg, so what are the fields in you blocks, may need to post a dwg.
From AutoCAD Help PROPULATE (Express Tool): https://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-BD03320F-3430-4C2F-80A3-AAC1167AF019
This can also be done with lisp which is nice because you add a custom property to the list without knowing how many are already there or overwriting them.
I set Summary Title: to the drawing name along with a few custom properties after I chose the initial layout with title block for the project. I've got more macros in my customized Properties panel for selecting the engineer who'll sign the plans as well as setting other custom properties.
  On 3/25/2021 at 10:14 AM, ILoveMadoka said:
LeeMac to the rescue once again...
http://lee-mac.com/steal.html
Thank you so very much!
Custom Properties may be the only thing I hadn't used that lisp for. Must be referenced in my custom ribbon a few dozen times. Thanks Lee!
I had no idea it did Custom Properties.
Good deal LeeMac! Thanks for finding that ILoveMadoka!
