JerryG Posted March 17, 2021 Share Posted March 17, 2021 Hello all. Got a bit of an odd one. Just got a new laptop with Civil 2021 (version 2021.2) Everything works as expected until I try and open a drawing with previously created Pipes using Pipe Networks. Once I open the drawing I can see everything but it always just hangs and Civil stops responding. No Fatal errors it just never fully opens. I've waited over 40 minutes for the drawing to respond but it never does. This happens on any drawing I try to open with Pipes. These are drawings I've created that have worked fine on my previous computer with Civil 21 installed. this even happens on drawings created in previous versions. Thanks for aby input! Quote Link to comment Share on other sites More sharing options...
TRogers Posted March 17, 2021 Share Posted March 17, 2021 (edited) Sounds like you may need to reset your settings to default. Close Civil 3D... The easiest way to do this is to go to your Windows Registry Editor. Browse to HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R24.0\... There, you will see ACAD-4100:409. Right-click on it and delete it. Restart Civil 3D. Edited March 17, 2021 by TRogers 2 Quote Link to comment Share on other sites More sharing options...
JerryG Posted March 17, 2021 Author Share Posted March 17, 2021 Thanks TR. Trying that now. Quote Link to comment Share on other sites More sharing options...
JerryG Posted March 17, 2021 Author Share Posted March 17, 2021 (edited) TR - that worked perfect! Thank you! Edited March 18, 2021 by JerryG 1 Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted March 18, 2021 Share Posted March 18, 2021 Welcome to the forum, TRogers. Way to go, hit it out of the park on your first at-bat! 1 Quote Link to comment Share on other sites More sharing options...
TRogers Posted March 18, 2021 Share Posted March 18, 2021 My pleasure @JerryG and thanks @CyberAngel! Quote Link to comment Share on other sites More sharing options...
JerryG Posted March 18, 2021 Author Share Posted March 18, 2021 I wanted to add a side note for future use to anyone experiencing the same or similar issues. We were about to delete my profile on the computer thinking that there was a setting that was preventing the DWG from fully opening. Even though it was a new computer and new install of Civil 3d my previous setting were still there from bringing over my profile for the new computer. By deleting my profile it would have set things back to a stock setting. This was a best guess based on the fact that other Designers could open the same file just fine and we had exhausted all other options besides doing a full reinstall of Civil 3d. (we did do a fix and repair install) TR's way was much faster and only affected CIvil 3d. Thank you again TRogers. 1 Quote Link to comment Share on other sites More sharing options...
TRogers Posted March 18, 2021 Share Posted March 18, 2021 My pleasure @JerryG Quote Link to comment Share on other sites More sharing options...
