happyhappycheese Posted February 8, 2009 Posted February 8, 2009 (edited) delete delete Edited May 13, 2011 by happyhappycheese delete Quote
Tankman Posted February 8, 2009 Posted February 8, 2009 Some nice title blocks ship with AutoCAD. Check those out. Is that what you need? Quote
ReMark Posted February 8, 2009 Posted February 8, 2009 A titleblock can be something as simple as a rectangular box in the lower right hand corner of your drawing that contains the: -Name & logo of the company that did the drawing. -Name of the project. -Scale of the drawing. -Date drawing was completed. -Initials of the person who did the drawing. -Drawing number. -Sheet number. As Tankman suggested, check out some of the sample drawings or templates that AutoCAD provides. There should also be examples on the Internet. Quote
Raggi_Thor Posted February 8, 2009 Posted February 8, 2009 For this project I don't think it's important how you do it. I think you should keep it simple. http://images.google.no/images?q=titleblock for example http://www.we-r-here.com/ Quote
Jillymaxo Posted September 22, 2009 Posted September 22, 2009 I posted a question on a thread about creating titleblocks in autocad 14. I am relearning and starting up my own business after raising children which I am still doing. All the tricks are coming back to me, but I am having trouble remembering how to make titleblocks in model space. Should I just make them in paper space? How do I know if it is the right size for the different sheet sizes? Quote
ReMark Posted September 22, 2009 Posted September 22, 2009 Release 14 huh? Good question. Are you going to make your drawings to "scale" as one would if doing it on the drafting board? How comfortable are you working in paper space? Quote
Jillymaxo Posted September 22, 2009 Posted September 22, 2009 Thanks for your reply. I have drawn them already in model space. I remember that I can have my titleblock in paperspace and then scale the drawing to whatever scale I want in the viewport such as 1/8" or 1/4" whatever fits best for they are small drawings. I just want to have titleblocks that are ready for print out on a 8.5 x 11 sheet and whatever the standard size is for blueline ( I think 24 x 3?) I know I can make all the different titleblocks and bring them in as xrefs or blocks, I just can't remember exactly how I used to do it. It has been 10 years. Thanks for your help! Quote
Jillymaxo Posted September 22, 2009 Posted September 22, 2009 Oh ReMark, I am comfortable in Paperspace and I meant 24 x 36 Quote
Tankman Posted September 22, 2009 Posted September 22, 2009 I use two title blocks, same information on both. One is portrait, one is landscape. Most often the landscape view. Quote
Raggi_Thor Posted September 22, 2009 Posted September 22, 2009 I am glad we think metric :-) A house plan going to be printed at 1:100, just scale the border and title block 100. 1:50 scale it 50 and soo on. Then Plot, Extents. Quote
Raggi_Thor Posted September 22, 2009 Posted September 22, 2009 I use two title blocks, same information on both.One is portrait, one is landscape. Most often the landscape view. It is good practice to have one title block and several borders (also blocks). Then you can (later) replace the border and keep the title block. Quote
ReMark Posted September 22, 2009 Posted September 22, 2009 You could create a "master" titleblock and border for your three or four common sheet sizes (24x36, 18x24, 11x17 and 8.5x11). These could be used where needed in model space, if you want, by scaling them accordingly. Working at 1/4"=1'-0" scale? Then scale the titleblock and border up by a factor of 48. Quote
Jillymaxo Posted September 22, 2009 Posted September 22, 2009 Ok, this is getting too confusing for me at the moment. I created an 8.5 x 11 boarder with a title block. I think it might be easier to create them all in model space and then bring them into paperspace for my drawings. That is how I used to do it, but the company I worked for had them all done! When creating them in model space how do I draw them?? Meanng just draw 8.0" x 10.5" so I have a boarder and then add the title block to it? It was so tiny in ms. I am not sure I understand how to scale the border when get it into paperspace. Please help! Quote
Raggi_Thor Posted September 22, 2009 Posted September 22, 2009 Just draw the border at correct size, offset for your paper margins. Then make a block of it. Draw the title block also at natural size. Use ATTDEF for to define attributes with tags like "Drawn_by", "Date" etc. Make a block of that one too, Insertion Base Pint at the lower right. Save that drawing and use ADC (Design center) to insert those blocks in other drawings. Or use W for WBLOCK to save the title block (and border) as a plain dwg file and use INSERT + Browse to insert it in other drawings. Now, in MS you scale the title block "up" when you insert it and then you scale everything "down" when you print or plot. So insert it with ascale factor of 48 for example (see the other thread on scale factors). In PS you "are on a paper sheet", insert the title block at scale 1. Then set a scale for the viewport(s). Quote
Raggi_Thor Posted September 22, 2009 Posted September 22, 2009 Of course you can combine the border an the title block in one block if think that's easier, for example if you use only one paper size. Quote
ReMark Posted September 22, 2009 Posted September 22, 2009 Draw everything full size. You might want to "orient" yourself by drawing a rectangle representing your paper size then placing your titleblock and border within this area. Pay attention to your layers, colors, and text style (font) now while creating these master sheets so you don't have to go back later and futz around with them. I'd also recommend starting in the lower left-hand corner at 0,0 and not out in space somewhere. Quote
Jillymaxo Posted September 22, 2009 Posted September 22, 2009 I don't mean to be a dingy blond from California, but this is all new to me since I haven't done this in 10 years. I understand bringing in the title sheets from a file as a block into paperspace but I just don't quite understand drawing them in model space because they all seem so small. When you say draw at natural size, does that mean in ms. or ps? I will need to just try it out. It seems to come back to me as I work on it. I drew one, like I said in paperspace and tried to thicken the lines and it wouldn't work for the boarder. I will do what you said in the above post. I am working with my old autocad 14 so I don't have all the modern conveniences of autocad 2009 with the libraries etc. Quote
Raggi_Thor Posted September 22, 2009 Posted September 22, 2009 Some tutorials might help, here is the first I found on google: http://www.roymech.co.uk/Useful_Tables/Drawing/Title_blocks.html http://www.mossdesigns.com/ADT2005titleblock.pdf Then you have some ready made like this: http://www.md.nrcs.usda.gov/technical/eng/title_blocks.html Quote
Jillymaxo Posted September 22, 2009 Posted September 22, 2009 Remark, When you say draw everything full size, do you mean in modelspace? Quote
