lozanoma Posted March 14, 2021 Share Posted March 14, 2021 Hello, everyone I have this code that has already ordered my list by the y coordinate, but I need to group them in columns with a predetermined number, and with this code I group them all, I attach two drawings, previous and what I need, thank you very much to all code: (defun _SortSSByXValdcha ( /); (setq BlkGroup newss) (if (eq (type BlkGroup) 'PICKSET) (progn (repeat (setq i (sslength BlkGroup)) (setq lst1 (cons (cons (setq e (ssname BlkGroup (setq i (1- i)))) (cdr (assoc 10 (entget e))) ) lst1 ) ) ) (setq add (ssadd)) (foreach e (vl-sort lst1 (function (lambda (a b) (cond ((> (cadr a) (cadr b))) ((= (cadr a) (cadr b)) (> (caddr a) (caddr b))) ) ) ) ) (ssadd (car e) add)); (if (> (sslength add) 0) add ) ) ) );end defun finally.dwg previous.dwg Quote Link to comment Share on other sites More sharing options...
rlx Posted March 15, 2021 Share Posted March 15, 2021 (defun c:t1 ( / ss el c r a l ip noc) (if (and (setq ss (ssget))(setq el (ss->lst ss))(setq c (getint "\nNo. groups horizontally (i.e. 4) : ")) (setq r (getint "\nNo. groups vertically (i.e. 2) : "))) (progn (foreach e el (if (not (setq a (assoc (car (setq ip (getIP e))) l))) (setq l (cons (cons (car ip) (list (cons (cadr ip) e))) l)) (setq l (subst (cons (car a) (cons (cons (cadr ip) e) (cdr a))) a l)))) (setq l (vl-sort l (function (lambda (a b) (< (car a) (car b))))) noc (fix (/ (length l) c))) (setq l (mapcar (function (lambda (c) (mapcar 'cdr (vl-sort (cdr c) (function (lambda (a b)(> (car a)(car b)))))))) l)) (setq l (split_list l noc)) (foreach sub l (foreach g (split_list (setq sub (apply 'mapcar (cons 'list sub))) (fix (/ (length sub) r))) (vlax-invoke (vla-add (vla-get-groups (vla-get-activedocument (vlax-get-acad-object))) "*") 'appenditems (mapcar 'vlax-ename->vla-object (apply 'append g))))) ) ) (princ) ) (defun split_list (l n / _sub) (defun _sub (a b c / r) (if (not (<= 1 c (- (length a) b)))(setq c (- (length a) (1- b)))) (repeat c (setq r (cons (nth (1- b) a) r) b (1+ b)))(reverse r))(if l (cons (_sub l 1 n) (split_list (_sub l (1+ n) nil) n)))) (defun ss->lst (ss / i l)(setq i 0)(repeat (sslength ss)(setq l (cons (ssname ss i) l) i (1+ i))) l) (defun getIP (e / d)(if (and (= 'ename (type e))(setq d (entget e))(setq d (assoc 10 d))) (cdr d))) 1 Quote Link to comment Share on other sites More sharing options...
lozanoma Posted March 16, 2021 Author Share Posted March 16, 2021 18 hours ago, rlx said: (defun c:t1 ( / ss el c r a l ip noc) (if (and (setq ss (ssget))(setq el (ss->lst ss))(setq c (getint "\nNo. groups horizontally (i.e. 4) : ")) (setq r (getint "\nNo. groups vertically (i.e. 2) : "))) (progn (foreach e el (if (not (setq a (assoc (car (setq ip (getIP e))) l))) (setq l (cons (cons (car ip) (list (cons (cadr ip) e))) l)) (setq l (subst (cons (car a) (cons (cons (cadr ip) e) (cdr a))) a l)))) (setq l (vl-sort l (function (lambda (a b) (< (car a) (car b))))) noc (fix (/ (length l) c))) (setq l (mapcar (function (lambda (c) (mapcar 'cdr (vl-sort (cdr c) (function (lambda (a b)(> (car a)(car b)))))))) l)) (setq l (split_list l noc)) (foreach sub l (foreach g (split_list (setq sub (apply 'mapcar (cons 'list sub))) (fix (/ (length sub) r))) (vlax-invoke (vla-add (vla-get-groups (vla-get-activedocument (vlax-get-acad-object))) "*") 'appenditems (mapcar 'vlax-ename->vla-object (apply 'append g))))) ) ) (princ) ) (defun split_list (l n / _sub) (defun _sub (a b c / r) (if (not (<= 1 c (- (length a) b)))(setq c (- (length a) (1- b)))) (repeat c (setq r (cons (nth (1- b) a) r) b (1+ b)))(reverse r))(if l (cons (_sub l 1 n) (split_list (_sub l (1+ n) nil) n)))) (defun ss->lst (ss / i l)(setq i 0)(repeat (sslength ss)(setq l (cons (ssname ss i) l) i (1+ i))) l) (defun getIP (e / d)(if (and (= 'ename (type e))(setq d (entget e))(setq d (assoc 10 d))) (cdr d))) Quote Link to comment Share on other sites More sharing options...
