Hi,all I'm faced stranger problem when i take copy from any values for any attribute block it gave my wrong value
like :
{\urtf1\fbidis\ansi\ansicpg65001\deff0\deflang3073{\fonttbl{\f0\fnil\fcharset0 Microsoft Sans Serif;}} \uc1\pard\ltrpar\f0\fs17 1D}
i don't know why.
any help appreciated
Are you saying that if you copy the value of an attribute to the windows clipboard, all of that is what gets copied?
Hi,thank for your kindly response.
Yes.
Any way you could share this drawing?
Even if you have to delete everything else in the drawing except for this block?
Hi,
I have tried to do same points in another workstation it is work correctly.
  • 3 years later...
did you ever find a solution to this?
Welcome to CADTutor!!
Can you post a .dwg and explain in more detail what's going on?
