This is more of a solution than a problem, in case it happens to someone else. tl;dr: When you publish a sheet set, you may get an unexpected alignment in your output.
I have a drawing created with LDD. I wanted to add a sewer profile, so I created an alignment. The alignment object was on layer 0 (not my choice), so I hid the object. It didn't show up in print preview. It didn't show up when I printed that one sheet to PDF. When I printed the whole set to PDF, though, the alignment appeared on the plans.
I have no idea why the "Dwg to PDF" plotter prints an alignment that doesn't print any other way. To fix it, I created an alignment style that puts everything on a non-plotting layer; problem solved.
