Slurpied Posted March 3, 2021 Share Posted March 3, 2021 Hi, I have a Polyline that is 17km long. I need to add vertices at approximately 250 unevenly spaced points along the line. For instance, I need a point at distance from start = 175.65m, another at 186.7m, 270.6m, etc. I have tried to modify the vtxdist.lsp I found online to iterate through a list but was unable to do so. Could anyone help me out with a lisp routine which allows me to read a list from a text file, or that I can paste my list directly into the lisp code? Copy of vtxdist.lsp to save you time: ;Add polyline vertices in intervals ;CAD Studio, www.cadstudio.cz www.cadforum.cz (defun C:VTXDIST ( / pline plineo pt ptpar stan int seg) (vl-load-com) (setq pline (entsel "\nSelect a polyline to divide/measure: ")) (if pline (progn (setq pline (car pline)) (setq plineo (vlax-ename->vla-object pline)) (if (member (cdr (assoc 0 (entget pline))) '("LWPOLYLINE" "SECTION")) (progn (if _lastVTXDIST (initget 6 "Number")(initget 7 "Number")) (setq int (getdist (strcat "\nSpecify the segment size or [Number]" (if _lastVTXDIST (strcat " <" (rtos _lastVTXDIST 2) ">") "") ":"))) (if (eq int "Number")(progn (initget 7) (setq seg (getint "\nNumber of segments: ")) (setq int (/ (vlax-get-property plineo 'Length) seg)) (princ (strcat " (size: " (rtos int 2) ")")) )) (if (not int)(setq int _lastVTXDIST)(setq _lastVTXDIST int)) (setq stan int) (while (setq pt (vlax-curve-getPointAtDist plineo stan)) (setq ptpar (vlax-curve-getParamAtPoint plineo pt)) (vlax-invoke plineo 'AddVertex (1+ (fix ptpar)) (list (car pt)(cadr pt))) (setq stan (+ stan int)) ); (princ " added.") (sssetfirst nil (ssadd pline)) ) ;else (princ " not a lwpolyline ! ") ) ;if eq )) ;if pline (prin1) ) Many thanks, Will Quote Link to comment Share on other sites More sharing options...
hosneyalaa Posted March 4, 2021 Share Posted March 4, 2021 ;Add polyline vertices in intervals ;CAD Studio, www.cadstudio.cz www.cadforum.cz ;;https://www.cadtutor.net/forum/topic/72403-add-polyline-vertices-at-chainage-points-from-a-list/ (defun C:READVTXDIST ( / pline plineo pt ptpar stan int seg F FILEPATH LN) (vl-load-com) (if (and (setq pline (entsel "\nSelect a polyline to divide/measure: ")) (setq FilePath (getfiled "Select TEXT file to read :" (getvar "dwgprefix") "txt" 4 ) ) ) (progn (setq pline (car pline)) (setq plineo (vlax-ename->vla-object pline)) (if (member (cdr (assoc 0 (entget pline))) '("LWPOLYLINE" "SECTION")) (progn (setq f (open FilePath "r")) ;;; (if _lastVTXDIST ;;; (initget 6 "Number") ;;; (initget 7 "Number")) ;;; (setq int (getdist (strcat "\nSpecify the segment size or [Number]" (if _lastVTXDIST (strcat " <" (rtos _lastVTXDIST 2) ">") "") ":"))) ;;; (if (eq int "Number") ;;; (progn ;;; (initget 7) ;;; (setq seg (getint "\nNumber of segments: ")) ;;; (setq int (/ (vlax-get-property plineo 'Length) seg)) ;;; (princ (strcat " (size: " (rtos int 2) ")")) ;;; )) ;;; (if (not int)(setq int _lastVTXDIST)(setq _lastVTXDIST int)) ;;; (setq stan int) (while (setq ln (read-line f)) (IF (<= (atof ln) (vla-get-length plineo) ) (progn (setq pt (vlax-curve-getPointAtDist plineo (atof ln))) (setq ptpar (vlax-curve-getParamAtPoint plineo pt)) (vlax-invoke plineo 'AddVertex (1+ (fix ptpar)) (list (car pt)(cadr pt))) ;;; (setq stan (+ stan int)) ) ) ); (while (princ " added.") (sssetfirst nil (ssadd pline)) ) ;else (princ " not a lwpolyline ! ") ) ;if eq )) ;if pline (prin1) ) AAaa.txt 1 Quote Link to comment Share on other sites More sharing options...
