SLaszlo Posted February 27, 2021 Share Posted February 27, 2021 I use a routine in acaddoc.lsp to set to change the value of "imageframe" system variable when opening a drawing. Recently I've tried to use it on a AutoCad 2007 and got an error. Seems like 2007 version doesn't have a system variable named "imageframe". I use the code below as a workaround for the problem, but I'm wondering is there a better way to change the value of "imageframe" when opening a new drawing for 2007 version? (if (getvar "imageframe") (setvar "imageframe" 2) (command "_imageframe" 2)) Quote Link to comment Share on other sites More sharing options...
eldon Posted February 27, 2021 Share Posted February 27, 2021 I am not sure when it was changed to a system variable, but in my version of AutoCAD (2002), IMAGEFRAME is a command. Quote Link to comment Share on other sites More sharing options...
Isaac26a Posted February 27, 2021 Share Posted February 27, 2021 I don't remember when it was changed, but in my 2010 version, it's a system variable, you can check your sistem variables using the command "sysvdlg" and probably what you want to do is something like this. (if (>= (atof (getvar "acadver")) 18.0) (setvar "imageframe" 2) (command "_imageframe" 2) ) But still don't know if is of much value Quote Link to comment Share on other sites More sharing options...
