KML to POINT
Paul Mc
I need to figure out a way without using any third party software to bring in a ZML or KMZ file from Google Earth into my project showing both the placemark and name.  I've trying creating a block with an attribute then using MAPINSERT command with the following attachments but can not get it working.  The final output I require is a Civil3D point with the proper coordinate and name.
  • 3 weeks later...
Hi Paul.
You 1st have to convert the KMZ file to a Text Document.
Once complete it should now be in Lat and Long Cord.
clean up the text file so that it only has the Point # Lat Long elev Desc.
In civil import the points using the top pull down menu.
Create a point style for Lat and Long.
Make sure that your geolocation is set to the same as your Data.
  • 2 months later...
