vasanthsv84 Posted February 24, 2021 Posted February 24, 2021 Goodday Everyone, I have created a vba code for creating Longitudinal section (inputs from excel), also I want to make a gap between the profiles if a row was empty in excel. Can anyone guide me through this!? Thanks Regards, Vasanth. S Quote
BIGAL Posted February 25, 2021 Posted February 25, 2021 You would use the cell is empty as a loop in a loop, if it was a csv file it would be read-line is "" Quote
vasanthsv84 Posted February 25, 2021 Author Posted February 25, 2021 Hi Bigal thanks for the response, can you please share a sample vba code to find the empty cell in excel. Thanks Quote
BIGAL Posted February 25, 2021 Posted February 25, 2021 Sorry I dont do much in VBA started to play with it but went back to lisp. Some else will help. Quote
vasanthsv84 Posted February 26, 2021 Author Posted February 26, 2021 Hi Bigal, it's ok. I found a way around to it. Thanks for the suggestions. GPT = Rng.Cells(RowIndex, 10) Select Case GPT Case "1" InsPtsST(0) = 0: InsPtsST(1) = 0: InsPtsST(2) = 0 Case "2" InsPtsST(0) = 0: InsPtsST(1) = -500: InsPtsST(2) = 0 Case "3" InsPtsST(0) = 0: InsPtsST(1) = -1000: InsPtsST(2) = 0 Case "4" InsPtsST(0) = 0: InsPtsST(1) = -1500: InsPtsST(2) = 0 Case "5" InsPtsST(0) = 0: InsPtsST(1) = -2000: InsPtsST(2) = 0 Case "6" InsPtsST(0) = 0: InsPtsST(1) = -2500: InsPtsST(2) = 0 End Select Quote
