Need help of excel script that can data link cell to CAD with a macro button
Hi everyone,
I have an excel panel schedule that would like to data link to CAD with a macro button in excel. If destinated CAD file is opened, when I clicked macro button, it will direct me to the CAD and ask me to pick the location to paste the panel schedule. The panel schedule would be data linked to the excel.
Thanks.
15 hours ago, SSSSS said:
Hi everyone,
Thanks.
You should modify the path for open a new template.
See picture below, you have to create a command button in excel, assign the macro below, and try.
Sub Macro_Cad()
    Dim acadApp As Object
'Check if AutoCAD is open.
   ' On Error Resume Next
    Set acadApp = GetObject(, "AutoCAD.Application")
    On Error GoTo 0
    'If AutoCAD is not opened create a new instance and make it visible.
   If acadApp Is Nothing Then
        Set acadApp = CreateObject("AutoCAD.Application")
        acadApp.Visible = True
   End If
    'Check if there is an active drawing.
    Set acadDoc = acadApp.ActiveDocument
    'No active drawing found. Create a new one.
    If acadDoc Is Nothing Then
        Set acadDoc = acadApp.Documents.Add("C:\Users\IO\AppData\Local\Autodesk\AutoCAD Mechanical 2021\R24.0\enu\Template\acad.dwt")
    End If
MyScreenPoint = acadDoc.Utility.GetPoint(, "Select Insertion Point: ")
Range("E3").Value = MyScreenPoint(0)
Range("F3").Value = MyScreenPoint(1)
Range("G3").Value = MyScreenPoint(2)
End Sub
