I want to create a polyline with pl command between points from 2 different layers.
Sorry for the low-quality photo. Is there an easy way to create a LISP bc there are thousands of points I need to do manually? Any help would be appreciated.
Need a little more information. Between what two points? The COGO point and the polyline perpendicular to it?
Maybe a simple solution.To draw an offset line from 2pts, pick pt1, pt2, get angle pt1 pt2, do polar for new pt3 and pt4 with offset, line pt3 pt4. Offset will always be to right based on the order of the pick points.
Like rkmcswain need more info as image has more than 2 points and which side right or left.
Are you talking car parking bays as that can be solved from a pline with offset.
Edited by BIGAL
