Hello.
In my drawing,
there are many blocks around and it says how many floors they are inside.
I want to extrude these blocks.
But since they are so numerous, it takes a long time to do it one by one.
I'm looking for a lisp to extrude these blocks according to the numbers written in them.
It also works to select polylines based on the numbers inside
I'm sorry for my bad english.
http://prntscr.com/yz55au
Edited by tahta07
  On 2/12/2021 at 5:11 AM, BIGAL said:
Post a dwg.
I posted
Here's a start:
(defun c:foo (/ i n p s sp)
  ;; RJP » 2021-02-12
  (if (setq s (ssget ":L" '((0 . "*POLYLINE"))))
    (progn (setq sp (vlax-ename->vla-object (cdr (assoc 330 (entget (ssname s 0))))))
	   (vl-cmdf "_.UNDO" "Be")
	   (setvar 'cmdecho 0)
	   (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	     (setq p nil)
	     (repeat (fix (setq i (vlax-curve-getendparam e)))
	       (setq p (cons (vlax-curve-getpointatparam e i) p))
	       (setq i (1- i))
	     (if (and (setq i (ssget "_WP" p '((0 . "TEXT"))))
		      (> (setq n (atof (cdr (assoc 1 (entget (setq i (ssname i 0))))))) 0)
	       ;; Vl extrusion is not as editable?
	       (progn ;; (setq r (car (vlax-invoke sp 'addregion (list (vlax-ename->vla-object e)))))
		      ;; (vlax-invoke sp 'addextrudedsolid r (* 3 n) 0.)
		      (vl-catch-all-apply 'vl-cmdf (list "_.extrude" e "" (* 3 n)))
	   (vl-cmdf "_.UNDO" "End")
	   (setvar 'cmdecho 1)
  • Thanks 1
  • 1 month later...
  On 4/7/2021 at 1:43 PM, tahta07 said:
Thank you sir its work 😍🤩
Glad to help 🍻
  • 5 months later...
  On 4/7/2021 at 2:30 PM, ronjonp said:
Glad to help 🍻
Sir
could you help me again?
Lisp works very well but it doesn't exturude 3DPOLYLINE  How can I exturude both 3dpolyline and polyline
Post a sample where it does not work. It should work unless there's something funky with the geometry.
Extrude a 3dpoly ?? Not sure can be done unless its a single planar surface and maybe set UCS. Think of a TIN surface.
Bricscad V20 would not let me, maybe doing something wrong.
Edited by BIGAL
