mhupp Posted February 8, 2021 Share Posted February 8, 2021 I cant figure out the if statement to test if my variable ent is a circle. defined by "(setq ent (car (nentselp pt)))" Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 8, 2021 Share Posted February 8, 2021 Why are you using the nentselp function ? are you after selecting nested object ? if not, then use the entsel function instead. To check if the selected object is a Circle: (= (cdr (assoc 0 (entget ent))) "CIRCLE") The above code should return T ( true ) if the object is Circle otherwise nil. 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted February 8, 2021 Author Share Posted February 8, 2021 (edited) Modifying a lisp Lee Mac made back in '09. it does what i need but doesn't work on circles. adding the if statement and using the trim command for when a circles is selected. (if (not (= (cdr (assoc 0 (entget ent))) "CIRCLE")) (command "_.break" (list ent pt) "_F" "_non" (polar pt ang (/ off 2.)) "_non" (polar pt (+ pi ang) (/ off 2.))) (progn (vl-cmdf "_circle" pt "0.0078") (setq obj (entlast)) (vl-cmdf "_view" "save" "s") (vl-cmdf "_Zoom" "OB" obj "") (vl-cmdf "_trim" obj "" pt "") (vl-cmdf "_erase" obj "") (vl-cmdf "_view" "restore" "s") ) ) And thank you for the help. Edited February 8, 2021 by mhupp Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 8, 2021 Share Posted February 8, 2021 (edited) You're welcome anytime. A few mods if you are interested. (if (= (cdr (assoc 0 (entget ent))) "CIRCLE") (progn (vl-cmdf "_circle" "_non" pt "0.0078") (setq obj (entlast)) (vl-cmdf "_view" "save" "s") (vl-cmdf "_Zoom" "OB" obj "") (vl-cmdf "_trim" obj "" "_non" pt "") (vl-cmdf "_erase" obj "") (vl-cmdf "_view" "restore" "s") ) (command "_.break" (list ent pt) "_F" "_non" (polar pt ang (/ off 2.)) "_non" (polar pt (+ pi ang) (/ off 2.)) ) ) Edited February 8, 2021 by Tharwat 1 Quote Link to comment Share on other sites More sharing options...
