Hello!
I have been getting suggestions and help from this forum for some time now, but have reached a point where I am currently at a loss.
I am still relatively new to the topic of lisp and co, but I am trying to improve constantly.
For my current problem, I am trying to select a block and insert a point into it.
I have simplified my current lisp file into the function below so as not to go over the top.
My problem is that I get back an empty selection set and thus can't execute the function from Lee Mac correctly.
(defun TestFunction ( / )
  (while (= ss NIL)
    (if (setq ss (ssget "_+.:S:E:L" '((0 . "INSERT"))))
        (setq ent (ssname ss 0))
        (setq Block (vla-item (vla-get-blocks (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))) (cdr (assoc 2 (entget (ssname ss 0))))))
        (Insert_Point)
(defun Insert_Point ( / )
  ;; Block Einfügepunkt ermitteln
  (setq Message (strcat "\nEinfügepunkt wählen:"))
  (setq Pnt (getpoint Message))
  (setq sel (ssadd))
  (setq Point (vla-addpoint Block (vlax-3d-point Pnt)))
  (ssAdd (vlax-vla-object->ename Point) sel)
  ;; sel stays empty so the following line cant be executed properly
  (UpdateBlock doc ent sel)
Many thanks for your help!
Best regards
Florian
Give this a try:
(defun c:testfunction (/ block doc ent pnt ss)
  (while (and (setq ss (ssget "_+.:S:E:L" '((0 . "INSERT"))))
	      (setq pnt (getpoint "\nEinfügepunkt wählen:"))
    (progn (setq ent (ssname ss 0))
	   (setq block
		  (vla-item (vla-get-blocks (setq doc (vla-get-activedocument (vlax-get-acad-object))))
			    (cdr (assoc 2 (entget ent)))
	   (vla-addpoint block (vlax-3d-point pnt))
Hello!
Thank you for your answer :)
I still got a problem, if the block is a dynamic one.
When I open the block in Blockeditor or just press attsync all points are gone.
How can I handle this problem?
Thank you!
6 hours ago, Florian said:
Hello!
Thank you!
Maybe try this:
	   (setq block
			    (vla-get-effectivename (vlax-ename->vla-object ent))
Hey :)
I still have a problem with updating the new points.
They are not visible in my drawing.
When I "attsync" the block, they are visible, but if I copy this block in a new drawing, they are totally gone again.
Additionally I can not vla-move this point in an other function.
Is it possible, I miss some kind of update?
Thanks for your time!
Best Regards Florian
  • 2 weeks later...
Hello :)
Does anyone have an idea, what I am doing wrong here?
