I just joined this forum and I would like to contribute one of my lisp: 'VERIFQTA"to verify the "Forced dimensions", that is to say the value has been changed ... and which often generate errors.
(I translate in english all message)
VERIFQTA.LSP
Edited by X11start
Welcome 🙂 and thanks for sharing.
I read your description and I think it might do the same as the code below.
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-change-color-of-dimensions-with-text-override/m-p/5103678/highlight/true#M323552
(defun c:dimover ( / ent i ss txt)
  (if (setq ss (ssget "_X" '((0 . "DIMENSION"))))
      (setq ent	(entget (ssname ss (setq i (1- i))))
	    txt	(cdr (assoc 1 ent))
      (if (not (or (= txt "") (wcmatch txt "*<>*")))
	(if (assoc 62 ent)
	  (entmod (subst (cons 62 2) (assoc 62 ent) ent)) ;; change the color 2 if needed
	  (entmod (append ent (list (cons 62 2)))) ;; change the color 2 if needed
It's actually a much simpler code than my! Thank you!
Here's another way to write it:
(defun c:dimover ( / i s )
    (if (setq s (ssget "_X" '((0 . "*DIMENSION")(1 . "*?*")(1 . "~*<>*"))))
        (repeat (setq i (sslength s))
            (entmod (append (entget (ssname s (setq i (1- i)))) '((62 . 1))))
  • Like 2
Many years ago I was a subscriber to a Commodore 64 newspaper: there was always a column called "one line" in which you tried to put a series of commands in a single line ... even a micro videogame! It was a very useful "synthesis" exercise to avoid creating too verbose codes! Your answers brought me back to those times! Thanks!
