Dynamic block - Lookup table for visibility states - not working
sketch11
Could be, one problem is I don't think dynamic blocks where designed with this type of project in mind, so there is no book of rules saying if you do this with a linear parameter then you need to do that with a rotation action. There are fairly good descriptions and rules of logic described in the help files but once you start combining all these elements then it is down to trial and error. That doesn't mean it isn't possible but it does make for a lot of headaches. All you can do is look at the block, try an action and follow what happens, and often it is just down to guess work.
The issues were related to the following:
- Basepoint needs to be at the origin (0, 0).
- Arbitrary parameters need to have correct inputs. Point Parameters need to be at the correct location representing visibility states ... or Distance Parameters need to have a length of 1.
- Basepoint is removed from the Flip action and replaced with a Point Parameter with a chain link.
Attached is a more recent version.
Drawing_Weld - 5_Feb.dwg
