Hi guys, you may be able to help, I use autocad lt2020, some how I managed to move a toolbar to the middle of the screen and cannot move it back, the small x is showing top right but the row of double dots top left of the tool bar is missing, how do I move it back
thank you Mike
You need to take a look at the variable 'LOCKUI' or right click on your toolbar and down at the bottom of the list of toolbars are the various options to dock toolbars
Sounds like @steven-g will have sorted you out.  :beer:
Alternately you can hold down the Ctrl button, and you should then be able to move it, even if it is locked.
  • Like 2
