haima Posted January 25, 2021 Share Posted January 25, 2021 hello i want to show the different angels in the same tab how can I do that? Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted January 25, 2021 Share Posted January 25, 2021 Do you mean that you want to show different views of the same object in a layout tab? You just need to create multiple floating viewports. More info here: 1 Quote Link to comment Share on other sites More sharing options...
Mugna101 Posted September 29, 2021 Share Posted September 29, 2021 (edited) You can also do that in the model which will result a split screen view i use Viewports in model area for making sure i snap on the correct point in pointcloud sometimes.. quite helpful Edited September 29, 2021 by Mugna101 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 30, 2021 Share Posted September 30, 2021 Angels Do you mean angles ? You can set a different view angle in any viewport, can use UCS and save the UCS direction by name if you want. UCS OB S Road1 etc 2 2 Quote Link to comment Share on other sites More sharing options...
Dana W Posted October 1, 2021 Share Posted October 1, 2021 haima has left the building. Maybe the angels came for them. 1 Quote Link to comment Share on other sites More sharing options...
