hello i want to show the different angels in the same tab how can I do that?
Do you mean that you want to show different views of the same object in a layout tab?
You just need to create multiple floating viewports.
More info here:
  • 8 months later...
You can also do that in the model which will result a split screen view
i use Viewports in model area for making sure i snap on the correct point in pointcloud sometimes.. quite helpful
Edited by Mugna101
Angels
Do you mean angles  ? You can set a different view angle in any viewport, can use UCS and save the UCS direction by name if you want. UCS OB S Road1 etc
  • Like 2
  • Funny 2
haima has left the building.  Maybe the angels came for them. :)
  • Funny 1
