Ahankhah Posted January 18, 2021 Posted January 18, 2021 Hi erverybody, when manipulating "MTEXT" objects, I can not get some information about this kind of object, while they are shown in "PROPERTIES" commands window. Should any one know where they are? One of the hidden properties of "MTEXT" is shown in PROPERTIES dialog, under "Text" region, with the lable "Columns". I appreciate greatly any help or clue guiding me to the solution. Quote
guran Posted January 18, 2021 Posted January 18, 2021 When you edit the text you find Text Editor in Ribbon. 1 Quote
BIGAL Posted January 19, 2021 Posted January 19, 2021 (edited) Removed Not right direction assoc 75 is 1 for multi columns then stuck. Edited January 19, 2021 by BIGAL Quote
Ahankhah Posted February 4, 2021 Author Posted February 4, 2021 On 1/18/2021 at 2:39 PM, guran said: When you edit the text you find Text Editor in Ribbon. Expand guran, you are right, but I have the mentioned problem when writing VLisp code. Quote
Ahankhah Posted February 4, 2021 Author Posted February 4, 2021 On 1/19/2021 at 6:53 AM, BIGAL said: Removed Not right direction assoc 75 is 1 for multi columns then stuck. Expand BIGAL, I don't understand, perhaps for English is not my mother language. Quote
tombu Posted February 4, 2021 Posted February 4, 2021 I use this lisp by BlackBox to expedite the setting of Columns to None as well as set Width to 0. https://www.augi.com/forums/showthread.php?170434-MText-width-set-to-zero&p=1330953&viewfull=1#post1330953 Discussion at that link may explain it as well. 1 Quote
Ahankhah Posted February 23, 2021 Author Posted February 23, 2021 On 2/4/2021 at 9:09 PM, tombu said: I use this lisp by BlackBox to expedite the setting of Columns to None as well as set Width to 0. https://www.augi.com/forums/showthread.php?170434-MText-width-set-to-zero&p=1330953&viewfull=1#post1330953 Discussion at that link may explain it as well. Expand tombu, thank you very much. Quote
