How to change alignment of MTEXT object, while vla-put-alignmentput isn't valid for it.
Hi all,
how is it possible to get and put alignment of a MTEXT object via AutoLISP?
I appreciate any help.
Edited by Ahankhah
It's the "AttachmentPoint" property... It's value is one of the following:
acTopLeft
acTopCenter
acTopRight
acMiddleLeft
acMiddleCenter
acMiddleRight
acBottomLeft
acBottomCenter
acBottomRight
Edited by Jonathan Handojo
Can use numbers a bit easier to type 1-9
AttachmentPoint = 5 middle centre.
I'm quite new to all the vla functions myself, so it took me a while to figure out how to use the list above.
But this works. Here is how to get the object:
(setq obj (vlax-ename->vla-object (car (entsel))))
And this to get the alignment of that object:
(vla-get-attachmentPoint obj)
And this to set the alignment of that object:
(vla-put-attachmentPoint obj 1)
Not sure how to add error handling and to check if the AttachmentPoint property actually exists in the object.
acTopLeft
acTopCenter
acTopRight
acMiddleLeft
acMiddleCenter
acMiddleRight
acBottomLeft
acBottomCenter
acBottomRight
Expand
Jonathan, thank you very much, but I am seeking then function to get/put these justifications from/on MTEXT object.
BIGAL, you are right, it is easier to type, but the writing code with constants is a good method to further references.
Expand
dexus,
this is exactly what I was searching for. Thank you very much.
Indeed I was searching something like: "alignment" or "justify" or "justifications" in the properties of "MTEXT".
Again I appreciate your kind help.
No problem. It's exactly as how @dexus pointed out. You can run into an error when applying for something that doesn't exist. I normally do:
(vla-put-AttachmentPoint obj acMiddleCenter)
You can pass it this way if you want to see whether it's valid:
(vl-catch-all-error-p (vl-catch-all-apply 'vla-put-AttachmentPoint (list obj num)))
Expand
If my explanation above returns T, then you know something is wrong. The number is invalid, or the layer of the text itself is locked/frozen, etc...
You can find out whether it's a number issue using vl-catch-all-error-message though. The returned message is "Automation Error. Invalid argument attPoint in DrawingDirection"
So in the end, it comes to something like the below
(if
	(setq err
		 (vl-catch-all-apply
		     (list
    (if (wcmatch (vl-catch-all-error-message err) "*Invalid argument attPoint in DrawingDirection")
	(princ "\nInvalid attachment")
	(princ "\nOther error")
  • 3 weeks later...
