Jim Clayton Posted January 14, 2021 Posted January 14, 2021 What's up gang. AutoCAD 2018. I have it now but I can't check drawings IN to Vault. I can check them OUT, just not IN. Is there a way to fix this? Thanks for all the help. Quote
ammobake Posted February 2, 2021 Posted February 2, 2021 Google brought this up. Worth a try I guess? Check the current Microsoft® Security configuration. Check the current Anti Virus Security configuration. ...Solution: Launch CAD-Application. Checking out the file. Check in the file without changing. Checking out the file a second time. Change the file. Check in should now work. Quote
ammobake Posted February 2, 2021 Posted February 2, 2021 Apparently user profiles can also get corrupted in vault. If that's the case, your profile has to be deleted in vault and set up from scratch. And ensure your vault working folder is mapped to the correct location and that your user profile has full read/write access to that location. Quote
tombu Posted February 8, 2021 Posted February 8, 2021 2013 thru 2017 drawings are type 2013 drawings. 2018 thru 2021 drawings are type 2018 drawings. I'm not a Vault user but I'd expect a different version of Vault would be needed to check a 2018 drawings IN as it couldn't be opened by anyone using a 2013 thru 2017 version. Quote
Jim Clayton Posted February 9, 2021 Author Posted February 9, 2021 I'll give this a try. I appreciate the help. Tks. Quote
