tmo793 Posted January 11, 2021 Posted January 11, 2021 Hi all. I've programmed in autolisp for a long time, I want to try my hand at .NET (VB) for AutoCAD 2021 but I've hit a roadblock just installing the tools required to follow this "My First AutoCAD Plug-In" tutorial. https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/my-first-autocad-plug-overview.html I'm on Win 10 Pro 64-bit, v20H2. It's a domain-joined PC but I have admin privileges. I use AutoCAD 2021 (vanilla). I've installed Visual Studio 2019 Community from the Microsoft website, seems to be working perfectly on its own - I can create a Hello World! app successfully. (installed v16.8.2 a month or so ago, updated to v16.8.3 this morning) I've downloaded and installed "objectarx_for_autocad_2021_win_64bit_dlm.sfx.exe" (by following links in the tutorial linked above, registering and getting a free license). It opens that usual AutoDesk SFX extractor, and extracts to the default location "C:\Autodesk\ObjectARX_for_AutoCAD_2021_Win_64bit_dlm". After extraction it closes, and doesn't appear to do anything. No error message, and no further installation windows. Older objectarx install instruction when I google it seem to indicate an installer should run next, from a "setup.exe" in the extracted folder. There is no "setup.exe" in my extracted folder. I've downloaded "AutoCAD_2021_dotnet_wizards.zip" (by following links in the tutorial linked above), extracted & installed "AutoCADNetWizards.msi" - The installer appears, it all seems to work perfectly. I open visual studio, create new project, search for "autocad" and no templates are found. The only templates available are what came installed with VS2019. If anyone knows what I'm doing wrong or how I might be able to resolve it, please let me know. I've googled the life out of this issue, and it looks like I'm the only one encountering this problem (but I also note there are no guides that specifically address AC2021 and VS2019. They all apply to old versions of both) Quote
tmo793 Posted January 11, 2021 Author Posted January 11, 2021 More notes: In the Windows 10 "Settings / Apps / Apps & Features" list, I can see "AutoCAD 2021 .NET Wizards", "Autodesk ObjectARX 2021 Help Files" and "ObjectARX 2021 Wizards" installed I did find this forum post on the autodesk forums, there's no answer yet but one person provided a workaround but it's a very long winded solution that I'm not 100% certain gives the same result as the official wizards - https://forums.autodesk.com/t5/net/visual-studio-2019-install-autocad-customization/td-p/9988348 Quote
alicio Posted February 28, 2021 Posted February 28, 2021 I solved it using the way described by this post: https://github.com/ADN-DevTech/AutoCAD-Net-Wizards/issues/8: follow the listed steps: Run AutoCADNetWizards.msi, it should say setup success:) download the MSI Extractor,you can extract files from AutoCADNetWizards.msi you can get two zip files, one is AutoCADNetWizards\Visual Basic\Autodesk\AutoCAD 2021 VB plug‐in.zip, the other is AutoCADNetWizards\Visual C#\Autodesk\ AutoCAD 2021 CSharp plug‐in.zip copy these two template zip files to the visual studio template fold like this in my machine:D:\My Documents\Visual Studio 2019\Templates\ProjectTemplates Run the visual studio and new a project, in the templates select window, type "autocad" in the search text box, then you should find these two .net templates! good luck! 1 Quote
tmo793 Posted March 29, 2021 Author Posted March 29, 2021 Thank you so much for this response - it seems to have done the trick! Quote
