Shivani Posted January 6, 2021 Share Posted January 6, 2021 I have multiple DXF files for a map. I want to change the units to meters for all and save them as .dwg files. Can it be done together with the help script and scriptpro? Can anyone help me with that? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 6, 2021 Share Posted January 6, 2021 (edited) Are the dxf files set to metres or unitless ? Why would you not insert or dxfin to a dwg with units set to metres. A script that opens a dxf resets units and saves no problem. Could do a hundred dxf's. Do you know how to write a script ? Can you post 1 dxf ? Edited January 7, 2021 by BIGAL Quote Link to comment Share on other sites More sharing options...
PeterPan9720 Posted January 10, 2021 Share Posted January 10, 2021 On 1/6/2021 at 5:13 PM, Shivani said: I have multiple DXF files for a map. I want to change the units to meters for all and save them as .dwg files. Can it be done together with the help script and scriptpro? Can anyone help me with that? If objects inside the drawing are blocks, you cant modify the units without modify and insert again it with measuring changes. No problem for DXF, you can save all file name in txt file, create a VBA procedure which open file and save as dxf. Quote Link to comment Share on other sites More sharing options...
