Ahankhah Posted January 6, 2021 Posted January 6, 2021 Hi all, I have written a simple routine using "SET" function. It runs in AutoCAD 2021 & 2020 without any problem, but when loading it in AutoCAD 2019 (and also in 2016) I found that "SET" function is redefined by some AutoCAD built-in function (or by Express Tools). It seems to be similar to another function named "SET$" and changes some "Dimensions variables". Do any one know whre this change is made and how I can reset "SET" function to its original definition? I appreciate any help. Quote
dan20047 Posted January 6, 2021 Posted January 6, 2021 (edited) My assumption is that you have customization that is making this change. When I run into problems like this I first search my entire lisp collection for the suspect code "set$". I use Textpad as my editor and it will search folders recursively showing list of files with matches. Another option is a program like Search Everything, https://www.voidtools.com/, which can index every file on multiple drives, and can search for content in the files, though slowly. (I use Search Everything every day as a quick launcher.) A work around would be to put code into the first loaded customization that saves SET to a temporary global variable, and resets it at the last loaded. I can't remember what gets loaded first, but for the last I would use s::startup. : (setq t1 SET) #<<FUNCTION> #x2 @fffdc4e66> : !t1 #<<FUNCTION> #x2 @fffdc4e66> : (setq SET "don't do this") "don't do this" : (SET 'a "b") ; ----- Error around expression ----- (SET 'A "b") ; error : no function definition <SET> ; expected FUNCTION at [eval] : (setq SET t1) #<<FUNCTION> #x2 @fffdc4e66> : (SET 'a "b") "b" : !a "b" Edited January 6, 2021 by dan20047 2 Quote
BIGAL Posted January 6, 2021 Posted January 6, 2021 (edited) Another I use is from CMD level "Findstr" cd to directory to check eg cd c:\acadtemp\lisp Findstr set *.lsp Edited January 6, 2021 by BIGAL 2 Quote
Ahankhah Posted January 9, 2021 Author Posted January 9, 2021 On 1/6/2021 at 6:31 PM, dan20047 said: My assumption is that you have customization that is making this change. When I run into problems like this I first search my entire lisp collection for the suspect code "set$". I use Textpad as my editor and it will search folders recursively showing list of files with matches. Another option is a program like Search Everything, https://www.voidtools.com/, which can index every file on multiple drives, and can search for content in the files, though slowly. (I use Search Everything every day as a quick launcher.) A work around would be to put code into the first loaded customization that saves SET to a temporary global variable, and resets it at the last loaded. I can't remember what gets loaded first, but for the last I would use s::startup. : (setq t1 SET) #<<FUNCTION> #x2 @fffdc4e66> : !t1 #<<FUNCTION> #x2 @fffdc4e66> : (setq SET "don't do this") "don't do this" : (SET 'a "b") ; ----- Error around expression ----- (SET 'A "b") ; error : no function definition <SET> ; expected FUNCTION at [eval] : (setq SET t1) #<<FUNCTION> #x2 @fffdc4e66> : (SET 'a "b") "b" : !a "b" dan20047, You are absolutely right., Thank you very much. Expand 1 Quote
Ahankhah Posted January 9, 2021 Author Posted January 9, 2021 On 1/6/2021 at 11:52 PM, BIGAL said: Another I use is from CMD level "Findstr" cd to directory to check eg cd c:\acadtemp\lisp Findstr set *.lsp Expand BIGAL, thank you for your reply and introducing the program. Quote
BIGAL Posted January 9, 2021 Posted January 9, 2021 Another I use is "Everything" it is a find file program comes in handy. 1 Quote
Ahankhah Posted January 10, 2021 Author Posted January 10, 2021 On 1/9/2021 at 9:53 PM, BIGAL said: Another I use is "Everything" it is a find file program comes in handy. Expand Quote
