Randomness
paulmcz
I have a problem I'd like to solve with lisp. I have 151 balls that I need to distribute somewhat randomly inside a cylinder Ø120 x 180"H by moving each in "Z" direction to its own elevation. The balls were polar arrayed in elevation 0.
(defun c:rand (/ n a b el nm sl ss osn)
  (command "_.undo" "begin")
  (setq	osn (getvar "osmode")
	h   (getdist "\n Space to fill height?: ")
	ss  (ssget)
	sl  (sslength ss)
	n   (/ (float h) (- sl 1))
	a   0
  (setvar "osmode" 0)
  (repeat sl
    (setq b (* n a)
	  el (list 0 0 b)
	  a (1+ a)
	  sl (1- sl)
	  nm (ssname ss sl)
    (command "move" nm "" (list 0 0 0) el)
  (setvar "osmode" osn)
  (command "_.undo" "end")
If I select each one by one in random order to create selection set in the lisp here, the ball are processed in order I picked them. But I'd like to select them in one shot with crossing window, because I will have hundreds of them in the next project.
Is there a way to force 'ssget' to create selection set where the objects are numbered in random order?
Or a way to step through the selection set in random order?
Thanks
Random.dwg
Edited by paulmcz
Give this a try:
(defun c:foo (/ el n p s)
  ;; http://www.lee-mac.com/random.html
  ;; Rand  -  Lee Mac
  ;; PRNG implementing a linear congruential generator with
  ;; parameters derived from the book 'Numerical Recipes'
  (defun lm:rand (/ a c m)
    (setq m   4294967296.0
	  a   1664525.0
	  c   1013904223.0
	  $xn (rem (+ c
		      (* a
			 (cond ($xn)
			       ((getvar 'date))
		   m
    (/ $xn m)
  ;; Random in Range  -  Lee Mac
  ;; Returns a pseudo-random integral number in a given range (inclusive)
  (defun lm:randrange (a b) (+ (min a b) (fix (* (lm:rand) (1+ (abs (- a b)))))))
  (if (and (setq n (getdist "\nEnter height: ")) (setq s (ssget ":L" '((0 . "INSERT")))))
    (foreach b (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
      (setq p (cdr (assoc 10 (setq el (entget b)))))
      (entmod (append el (list (list 10 (car p) (cadr p) (lm:randrange 0 n)))))
Wow, Ron, this is gold.
I have to study it to know what is going on there. I have seen the lisp on Lemac site but I had no idea of how to use it for my purpose.
Thanks very much. It is a great help.
You're welcome but most of the credit should go to Lee. 🍻
