I am trying to figure a way to repath PDFs and Images within a drawing.
I have a drawing that has PDFs and Images attach to it and are located in a Library folder.
I usually copy the drawing into a project folder. However, I do not want to reference Library Folder.
I did not know if there is a method or command, that can Copy the Images and PDFs from the Library Folder into where the drawing is saved, and then repath them to no path.
Honestly, it would be great to path to a subfolder where the drawing is saved, but would i think its easier to a no path.
Sorry for rumbling on about this. Thank you for any ideas.
Have you tried ETRANSMIT to a folder?
Seems to gather everything (and a bit more) and you can remove paths from xrefs and images.
I have not. Let me play with that and see what if I can get it to do, what I need it to.
