sketch11 Posted December 15, 2020 Share Posted December 15, 2020 Is there a setting to automatically adjust the height of table rows. The adjustment is only made if the height increases, but not if it decreases. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 18, 2020 Share Posted December 18, 2020 You can reset any row using (vla-SetRowHeight Objtable rownum rowht) you get how many rows then use a repeat to step through the rows. ; (vla-SetRowHeight Objtable row rowht) would change the 3rd row as rows start at 0. (setq objtable (vlax-ename->vla-object (car (entsel "\nPick table ")))) (setq rownum (vla-get-rows objtable)) (setq x 0) (repeat (- rownum 1) (vla-SetRowHeight Objtable (setq x (+ x 1)) rowht) ) Quote Link to comment Share on other sites More sharing options...
sketch11 Posted December 18, 2020 Author Share Posted December 18, 2020 Thanks BIGAL, I was asking with respect to a setting. With the LISP, it's along the same lines as manually adjusting. The reason is that more often than not, I forget to adjust or as the case may be, run the LISP. In a similar manner to when the row increases in size, this is done automatically by AutoCAD. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 18, 2020 Share Posted December 18, 2020 Happy to find out if there is some way to do it looked a couple of times. Its not exposed in properties. Quote Link to comment Share on other sites More sharing options...
sketch11 Posted December 18, 2020 Author Share Posted December 18, 2020 OK no worries then. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 18, 2020 Share Posted December 18, 2020 Run Dumpit on a table like dims a stack of options maybe just one needs to be reset. Quote Link to comment Share on other sites More sharing options...
sketch11 Posted December 18, 2020 Author Share Posted December 18, 2020 Sorry BIGAL but I can't understand what you mean. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 18, 2020 Share Posted December 18, 2020 Use this pick an object reveals all sorts of stuff. Pick a table and a dim. ;;;===================================================================; ;;; DumpIt ; ;;;-------------------------------------------------------------------; ;;; Dump all methods and properties for selected objects ; ;;;===================================================================; (defun C:Dumpit ( / ent) (while (setq ent (entsel)) (vlax-Dump-Object (vlax-Ename->Vla-Object (car ent)) ) ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
sketch11 Posted December 18, 2020 Author Share Posted December 18, 2020 OK thanks I tried it, there was a bunch of properties. The relevant one, I'm guessing it's relevant showed nothing. RowHeight (RO) = ...Indexed contents not shown... Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 18, 2020 Share Posted December 18, 2020 (edited) Ok found maybe an answer you need to work out the cell margins. But again by program (vlax-put Obj 'VertCellMargin 5) Edited December 18, 2020 by BIGAL Quote Link to comment Share on other sites More sharing options...
sketch11 Posted December 18, 2020 Author Share Posted December 18, 2020 OK I'm guessing "entmake" is a LISP routine ... to make a Table? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 18, 2020 Share Posted December 18, 2020 Both posted at same time. Quote Link to comment Share on other sites More sharing options...
sketch11 Posted December 18, 2020 Author Share Posted December 18, 2020 I do see this in there. But if I type "VERTCELLMARGIN", it says unknown command. VertCellMargin = 1.5 I can't understand what I'm supposed to do with "(vlax-put Obj 'VertCellMargin 5)". I tried to enter into the command line but nothing works. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 19, 2020 Share Posted December 19, 2020 OK thats just a std display of the command, the obj is a VL object that has been selected. (setq obj (vlax-ename->vla-object (car (entsel "Pick table")))) (vlax-put Obj 'VertCellMargin 5) Quote Link to comment Share on other sites More sharing options...
sketch11 Posted December 19, 2020 Author Share Posted December 19, 2020 Sorry BIGAL you've lost me here. I tried various things including entering into the command line ... I don't know what happened but the table had all rows with a margin of what is input from above ... so something worked ... but I don't know what I did. But I still don't understand where the automation comes into it. Is this set and forget? Quote Link to comment Share on other sites More sharing options...
