How to Check if Dynamic Block has Linear parameters
Hello
i need a way to check if a dynamic block has a linear parameter or Not BY autolisp.
i don't need the value itself.i just wanna check if it has the type of "linear parameter" or not
thanks in advance
Edited by handasa
u would need to go into block editor, then parameters manager (command _PARAMETERS).
It would be on the list.
-ChriS
-ChriS
thank you ChriS.i want a way to check without using the bedit command.
thanks Magnum,i want to get the property type not the property name
3 minutes ago, Magnum Z said:
This looks like it'll take time to understand, but this might be your best bet.
http://poleshchuk.spb.ru//cad/2009/tainypode.htm
Thanks Alot.i found a lisp written by Lee Mac and i modified it a little bit to check if the block has Stretch parameters or not.
it will return a list of the parameters names
(defun is-stretched (blk / plst)
    (if
        (and
            (vlax-property-available-p blk 'effectivename)
            (setq blk
                (vla-item
                    (vla-get-blocks (vla-get-document blk))
                    (vla-get-effectivename blk)
            (= :vlax-true (vla-get-isdynamicblock blk))
            (= :vlax-true (vla-get-hasextensiondictionary blk))
                (mapcar
                   '(lambda ( pair )
					(and
					(= 360 (car pair))
					(or
					(wcmatch (cdr (assoc 0 (entget (cdr pair)))) "BLOCKLINEARPARAMETER")
					(wcmatch (cdr (assoc 0 (entget (cdr pair)))) "BLOCKPOLARPARAMETER")
					(setq plst (cons (cdr (assoc 305 (entget (cdr pair)))) plst))
                    (dictsearch
                        (vlax-vla-object->ename (vla-getextensiondictionary blk))
                        "ACAD_ENHANCEDBLOCK"
plst
Perhaps:
(defun linearparam-p ( blk / ent )
    (and (setq ent (tblobjname "block" blk))
         (setq ent (cdr (assoc 360 (member '(102 . "{ACAD_XDICTIONARY") (entget (cdr (assoc 330 (entget ent))))))))
         (vl-some '(lambda ( x ) (and (= 360 (car x)) (= "BLOCKLINEARPARAMETER" (cdr (assoc 0 (entget (cdr x))))))) (dictsearch ent "acad_enhancedblock"))
_$ (linearparam-p "dynamic_block")
T
Edited by Lee Mac
21 hours ago, Lee Mac said:
Perhaps:
T
thanks Lee.this did the trick.thanks alot
  • 3 years later...
Hi,
It is possible to change this code to check if block contain a visibility parameter? I have tried to do it based on your last code, but with no luck..
Sure -
(defun visibilityparam-p ( blk / ent )
         (vl-some '(lambda ( x ) (and (= 360 (car x)) (= "BLOCKVISIBILITYPARAMETER" (cdr (assoc 0 (entget (cdr x))))))) (dictsearch ent "acad_enhancedblock"))
Alternatively, you could use my Get Visibility Parameter Name function, or the function I posted here.
Multi radio buttons.lspUsing Lee's great code Get visibility you can get all the values and pop them into a DCL so choose which one to use.
An example, you need to download Lee's dynamic block lisp and give it a name edit code to suit.
; Change dynamic block properties when inserting look at properties available.
; By Alan H June 2022
;; Get Dynamic Block Property Allowed Values  -  Lee Mac
;; Returns the allowed values for a specific Dynamic Block property.
;; Set Dynamic Block Visibility State  -  Lee Mac
;; Sets the Visibility Parameter of a Dynamic Block (if present) to a specific value (if allowed)
;; Get Visibility Parameter Name  -  Lee Mac
;; Returns the name of the Visibility Parameter of a Dynamic Block (if present)
(defun insdynv (blkname / pt obj lst ans)
(if (not LM:setdynpropvalue )(load "Lee-mac Dynamic block get-put"))
(setq pt (getpoint "\nPick a pt for block "))
(command "-insert" blkname "s" 1.0  pt 0)
(setq obj (vlax-ename->vla-object (entlast)))
(setq visval (LM:getvisibilityparametername obj))
(setq lst (LM:getdynpropallowedvalues obj visval))
(setq lst (cons "Please choose" lst))
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(if (not AHbut)(setq AHbut 1))
(setq ans (ah:butts 1 "v"  lst))
(LM:SetVisibilityState obj ans)
Edited by BIGAL
