Trudy Posted December 14, 2020 Share Posted December 14, 2020 (edited) Hello, i want to ask for help with creating closed polygon from Grid lines with lisp. Regards Trudy Edited September 7, 2022 by Trudy Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted December 14, 2020 Share Posted December 14, 2020 (edited) I'd recommend that you create single one, set variable (setq el (entlast)) and then do ARRAYCLASSIC - Rectangular option... Finally you iterate through newly created entities and change numbers in texts : (setq k 1) (while (setq el (entnext el)) (if (wcmatch (cdr (assoc 0 (entget el))) "*TEXT") (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat (substr (cdr (assoc 1 (entget el))) 1 (1- (strlen (cdr (assoc 1 (entget el)))))) (itoa (setq k (1+ k))))) (assoc 1 (entget el)) (entget el)))))) ) ) Edited December 16, 2020 by marko_ribar Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted December 14, 2020 Share Posted December 14, 2020 For Boxes only, you can try Enclosed Polylines Quote Link to comment Share on other sites More sharing options...
