juanragal Posted December 3, 2020 Posted December 3, 2020 Hi! I'm starting to feel comfortable in this forum, you always give a good answer. Thank you for your work! I want to insert new parameters in a dynamic block to set new values. I normally make atributes with an entmake method, but I never insert a parameter. I found Lee Mac's code to set or get dynamics block parameter values, but can't find anything about the created one. Thank you for advance. Quote
dlanorh Posted December 3, 2020 Posted December 3, 2020 1 hour ago, juanragal said: Hi! I'm starting to feel comfortable in this forum, you always give a good answer. Thank you for your work! I want to insert new parameters in a dynamic block to set new values. I normally make atributes with an entmake method, but I never insert a parameter. I found Lee Mac's code to set or get dynamics block parameter values, but can't find anything about the created one. Thank you for advance. As far as I know, you can't. SEE HERE for explanation Quote
juanragal Posted December 3, 2020 Author Posted December 3, 2020 15 minutes ago, dlanorh said: As far as I know, you can't. SEE HERE for explanation Oh... I'm sad to read that... Ok. thank you. Quote
