drafix cad ultra V4.20 (DOS) Importing?
So  I have 2 CAD programs drafix cad ultra V4.20 (DOS) and cadstat pro v3.7.5
I have exported from cadstat a DXF drawing to a USB A drive, My dos program wants the "file name and it's path on the command line, for example,     C:\dfx\dwg\ drawing name.dxf"
DOS program imports and exports as Autocad.dxf, It's asking "select file name  > C:\dfx\)(.dxf"  <-----wants me to type here
So I want to put in A:\dfx\dwg\br549.dxf ------does not work
Are you sure its A: ?
Try reversing \ A:/dxf/dwg/br549.dxf its a dos thing.
The way the path is written above, in both examples, indicates that the DWG subdirectory is contained within the DXF directory.  Wouldn't it be the just the opposite assuming you have both?
