Linda J Posted November 11, 2020 Posted November 11, 2020 Hi my name is Linda, i still use the old Drafix .CAD drawing package. the other day I tried to change my symbol libaray and picked a corrupt one by accident. It shut down Drafix and now wont let me opening it back up. when i click on the icon it comes up with the following error message, CAD.EXE has stopped working A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. Usually i can reopen it and just not use that symbol file but now i cant access the program at all. How do i get around this please? Quote
f700es Posted November 11, 2020 Posted November 11, 2020 Hi Linda, what Windows version are you using this on? Silly question but please bear with me but have you restarted the PC and tried to open Drafix again? Quote
BIGAL Posted November 13, 2020 Posted November 13, 2020 Does it have a desktop Icon if so look for the start up in Properties right click once you may be able to open it by changing a switch it may be as simple as starting template is now corrupt for Autocad the /p Myprofileetc to run a profile that is corrupt can screw it up. Quote
