Jéferson Gustavo Posted November 8, 2020 Share Posted November 8, 2020 Hello everyone! I have a list with several other sublists of five elements each, I need to create a function that verifies that the first four elements of each sublist are the same, if they are, join the two sublists in one, and add the last number of the two sublists, for example: ((1 1 1 1 3) (2 2 2 2 3) (1 1 1 1 4)) The function would return ((1 1 1 1 7) (2 2 2 2 3)) Thank you in advance! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted November 8, 2020 Share Posted November 8, 2020 (edited) Quickly written: (defun foo ( l / k r z ) (foreach x l (setq k (reverse (cdr (reverse x)))) (if (vl-some '(lambda ( y ) (if (apply 'and (mapcar '= k y)) (setq z y))) r) (setq r (subst (append k (list (+ (last z) (last x)))) z r)) (setq r (cons x r)) ) ) (reverse r) ) _$ (foo '((1 1 1 1 3) (2 2 2 2 3) (1 1 1 1 4))) ((1 1 1 1 7) (2 2 2 2 3)) Edited November 8, 2020 by Lee Mac Quote Link to comment Share on other sites More sharing options...
Tharwat Posted November 8, 2020 Share Posted November 8, 2020 Here is one way. (setq lst '((1 1 1 1 3) (2 2 2 2 3) (1 1 1 1 4))) (foreach itm lst (setq one itm) (mapcar '(lambda (k) (if (vl-every '(lambda (a b) (= a b)) (setq c (mapcar '+ '(0 0 0 0) one)) (mapcar '+ '(0 0 0 0) k)) (progn (setq rtn (cons (append c (list (+ (nth 4 one) (nth 4 k)))) rtn)) (setq lst (vl-remove one lst) lst (vl-remove k lst)) ) (setq rtn (cons (list k) rtn)) )) (cdr lst) ) ) Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted November 8, 2020 Share Posted November 8, 2020 (defun f (l / r) (setq l (vl-sort l '(lambda (a b) (cond ((/= (car a) (car b)) (> (car a) (car b)));(not (equal (car a) (car b) 1e-8)) ((/= (cadr a) (cadr b)) (> (cadr a) (cadr b))) ((/= (caddr a) (caddr b)) (> (caddr a) (caddr b))) (T (> (cadddr a) (cadddr b))) ) ) ) r (list (car l)) ) (foreach x (cdr l) (if (vl-every '(lambda (a b c) (= a b)) x (car r) '(0 0 0 0)) (setq r (cons (mapcar '(lambda (a b c) (if c (+ a b) a)) x (car r) '(nil nil nil nil T)) (cdr r))) (setq r (cons x r)) ) ) r ) Quote Link to comment Share on other sites More sharing options...
Grrr Posted November 8, 2020 Share Posted November 8, 2020 (defun f ( L / c v k fnd ) (foreach x (mapcar 'reverse L) (setq v (car x) k (reverse (cdr x)) c (cond ( (not (setq fnd (assoc k c))) (cons (list k v) c) ) ( (subst (list k (+ v (cadr fnd))) fnd c) ) ); cond ); setq ); foreach (if c (mapcar '(lambda (x) (append (car x) (list (last x)))) (reverse c))) ); defun _$ (f '((1 1 1 1 3) (2 2 2 2 3) (1 1 1 1 4))) ((1 1 1 1 7) (2 2 2 2 3)) Quote Link to comment Share on other sites More sharing options...
Jéferson Gustavo Posted November 9, 2020 Author Share Posted November 9, 2020 Your capacity is impressive, it worked perfectly, thank you all! Quote Link to comment Share on other sites More sharing options...
pBe Posted November 12, 2020 Share Posted November 12, 2020 (Defun foot (lst / a b c d e f x nlst) (While (setq a (Car lst)) (setq x (Cdr lst)) (setq b (reverse a) c (Car b) d (cdr b) ) (while (setq e (car x)) (if (equal (cdr (reverse e)) d) (setq c (+ (last e) c)) (setq g (cons e g)) ) (setq x (cdr x)) ) (setq nlst (cons (append d (list c)) nlst) lst g g nil ) ) nlst ) Test (setq lst '((1 1 1 1 3) (2 2 2 2 3) (1 1 1 1 4))) _$ (foot lst) ((1 1 1 1 7) (2 2 2 2 3)) _$ (foo lst) ((1 1 1 1 7) (2 2 2 2 3)) _$ (F:S lst) ((1 1 1 1 7) (2 2 2 2 3)) _$ (F:G lst) ((1 1 1 1 7) (2 2 2 2 3)) _$ (setq lst '((1 1 1 1 3) (2 2 2 2 2 3) (1 1 1 1 4) (1 1 1 1 1 4)(2 2 2 2 2 7))) ((1 1 1 1 3) (2 2 2 2 2 3) (1 1 1 1 4) (1 1 1 1 1 4) (2 2 2 2 2 7)) _$ (foot lst) ((1 1 1 1 7) (2 2 2 2 2 10) (1 1 1 1 1 4)) _$ (foo lst) ((1 1 1 1 7) (2 2 2 2 2 10) (1 1 1 1 1 4)) _$ (F:S lst) ((1 1 1 1 8) (2 2 2 2 4)) _$ (F:G lst) ((1 1 1 1 7) (2 2 2 2 2 10) (1 1 1 1 1 4)) 2 Quote Link to comment Share on other sites More sharing options...
